cherbz
PC Specification: Vista SP2 32- GeForce GTX 550Ti 2.4Ghz
Action! wont load / stuck on splash screen.
Sun Jan 11, 2015 1:33 am
Hi all,
I am a new user and just bought a license for this software, but not able to get it working yet.
My issue is that when I try to load it, the Action! splash screen with the grey and red graphic and reading version 1.20.2.0 pops up, and does not progress past that screen*
*I did once get into Action! once out of about 50 attempts so far. Did not attempt to use it that time as I wanted to solve the loading issue first.
I am using Windows Vista with SP2
DirectX11
3 Gig RAM
NVIDIA GeForce GTX 550 Ti (1gig)
Using dual monitors. Extended, One running at 1080p, the other at 1050p.
Some notes:
I am trying the 'run as admin' setting. The one time I did get in to Action!, it was with the 'run as admin' setting. My windows profile is already admin, so I'm not sure if that is necessary.
I have tried:
Uninstall/reinstall
When I use Action's uninstall, it leaves behind a file 'action_svc.exe'. I cant delete it as it says its in use by another application. If I try to reinstall Action! to the same directory, I get a prompt saying "error opening 'action_svc.exe" which I need to click 'ignore'.
Have tried uninstall + manually delete registry keys + Install app to a different location. (don't get the above prompt if I put it in a different directory. However same issue exists.
Tried to attach dxdiag but forum rejects file type, even with no extension.
cherbz
Re: Action! wont load / stuck on splash screen.
Tue Jan 13, 2015 11:04 pm
An update to the above;
- Have updated to the latest version for my video card.
Over the weekend I have been able to get Action running a few times. I seemed to get more success when I switched to using only a single monitor.
I have been able to record and use the software 4 or 5 times but now it again wont progress past the splash screen.
Please advise, I need to get this up and running smoothly asap.
cherbz
Tue Jan 13, 2015 11:30 pm
When Action is stuck on the spash screen, it is showing 3 processes running in the task manager;
Action.exe
Action_login.exe
Action_x86.bin
and in the Applications, it's showing 'test'.
Have also tried to disable firewall and antivirus software. Still not loading.
Fri Jan 16, 2015 4:25 pm
Could you post a DxDiag report of your PC?
cherbz
Sat Jan 17, 2015 12:58 am
radi wrote:Could you post a DxDiag report of your PC?
Yes will post it below.
During the week I figured out that Action! will load if I have a directx game running. If I have a fresh boot of windows, I would not get past the splash screen.
System Information
Time of this report: 1/17/2015, 11:52:44
Machine name: CHRIS-PC
Operating System: Windows Vista™ Ultimate (6.0, Build 6002) Service Pack 2 (6002.vistasp2_gdr.130707-1535)
Language: English (Regional Setting: English)
System Manufacturer: INTEL_
System Model: DP35DP__
BIOS: Default System BIOS
Processor: Intel(R) Core(TM)2 Quad CPU Q6600 @ 2.40GHz (4 CPUs), ~2.4GHz
Memory: 3062MB RAM
Page File: 2195MB used, 4143MB available
Windows Dir: C:\Windows
DirectX Version: DirectX 11
DX Setup Parameters: Not found
DxDiag Version: 7.00.6002.18107 32bit Unicode
DxDiag Notes
Display Tab 1: No problems found.
Display Tab 2: No problems found.
Sound Tab 1: No problems found.
Sound Tab 2: The file ctaud2k.sys is not digitally signed, which means that it has not been tested by Microsoft's Windows Hardware Quality Labs (WHQL). You may be able to get a WHQL logo'd driver from the hardware manufacturer.
Sound Tab 3: The file ctaud2k.sys is not digitally signed, which means that it has not been tested by Microsoft's Windows Hardware Quality Labs (WHQL). You may be able to get a WHQL logo'd driver from the hardware manufacturer.
Input Tab: No problems found.
DirectX Debug Levels
Direct3D: 0/4 (retail)
DirectDraw: 0/4 (retail)
DirectInput: 0/5 (retail)
DirectMusic: 0/5 (retail)
DirectPlay: 0/9 (retail)
DirectSound: 0/5 (retail)
DirectShow: 0/6 (retail)
Display Devices
Card name: NVIDIA GeForce GTX 550 Ti
Manufacturer: NVIDIA
Chip type: GeForce GTX 550 Ti
DAC type: Integrated RAMDAC
Device Key: Enum\PCI\VEN_10DE&DEV_1244&SUBSYS_351A1458&REV_A1
Display Memory: 2252 MB
Dedicated Memory: 977 MB
Shared Memory: 1274 MB
Current Mode: 1920 x 1080 (32 bit) (60Hz)
Monitor: Generic PnP Monitor
Driver Name: nvd3dum.dll,nvwgf2um.dll,nvwgf2um.dll
Driver Version: 9.18.0013.4709 (English)
DDI Version: 11
BGRA Supported: Yes
Driver Attributes: Final Retail
Driver Date/Size: 12/13/2014 21:02:10, 14128496 bytes
WHQL Logo'd: Yes
WHQL Date Stamp:
Device Identifier: {D7B71E3E-5104-11CF-8D65-17151CC2C435}
Vendor ID: 0x10DE
Device ID: 0x1244
SubSys ID: 0x351A1458
Revision ID: 0x00A1
Revision ID: 0x00A1
Video Accel: ModeMPEG2_A ModeMPEG2_C ModeVC1_C ModeWMV9_C
Deinterlace Caps: {6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(YV12,0x32315659) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(YV12,0x32315659) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(YV12,0x32315659) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YV12,0x32315659) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(IMC1,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(IMC1,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC1,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC1,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(IMC2,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(IMC2,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC2,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC2,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(IMC3,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(IMC3,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC3,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC3,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(IMC4,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(IMC4,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC4,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC4,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(S340,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(S340,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(S340,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(S340,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(S342,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(S342,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(S342,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(S342,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
DDraw Status: Enabled
D3D Status: Enabled
AGP Status: Enabled
Current Mode: 1680 x 1050 (32 bit) (59Hz)
DDI Version: 11
BGRA Supported: Yes
WHQL Logo'd: Yes
WHQL Date Stamp:
Vendor ID: 0x10DE
Device ID: 0x1244
Revision ID: 0x00A1
Revision ID: 0x00A1
D3D Status: Enabled
AGP Status: Enabled
Sound Devices
Description: Speakers (2- Razer Megalodon)
Default Sound Playback: Yes
Default Voice Playback: Yes
Hardware ID: USB\VID_1532&PID_000E&REV_0001&MI_00
Manufacturer ID: 65535
Product ID: 65535
Type: WDM
Driver Name: USBAUDIO.sys
Driver Version: 6.00.6002.18887 (English)
WHQL Logo'd: Yes
Date and Size: 7/12/2013 20:04:18, 73344 bytes
Other Files:
Driver Provider: Microsoft
HW Accel Level: Basic
Cap Flags: 0xF1F
Min/Max Sample Rate: 100, 200000
Static/Strm HW Mix Bufs: 1, 0
Static/Strm HW 3D Bufs: 0, 0
HW Memory: 0
Voice Management: No
EAX(tm) 2.0 Listen/Src: No, No
I3DL2(tm) Listen/Src: No, No
Sensaura(tm) ZoomFX(tm): No
Description: Speakers (Creative SB X-Fi)
Default Sound Playback: No
Default Voice Playback: No
Hardware ID: PCI\VEN_1102&DEV_000B&SUBSYS_00411102&REV_04
Manufacturer ID: 1
Product ID: 100
Type: WDM
Driver Name: ctaud2k.sys
Driver Version: 6.00.0001.1347 (English)
WHQL Logo'd: No
Date and Size: 4/21/2009 04:31:44, 536344 bytes
Other Files:
Driver Provider: Creative
Cap Flags: 0xF1F
HW Memory: 0
Description: SPDIF Out (Creative SB X-Fi)
Manufacturer ID: 1
Product ID: 100
Type: WDM
WHQL Logo'd: No
Other Files:
Cap Flags: 0xF1F
HW Memory: 0
Sound Capture Devices
Description: Microphone (2- Razer Megalodon)
Default Sound Capture: Yes
Default Voice Capture: Yes
Cap Flags: 0x1
Format Flags: 0xFFFFF
Description: Digital-In (Creative SB X-Fi)
Default Sound Capture: No
Default Voice Capture: No
Cap Flags: 0x1
Description: "What U Hear" (Creative SB X-Fi)
Cap Flags: 0x1
DirectInput Devices
Device Name: Mouse
Attached: 1
Controller ID: n/a
Vendor/Product ID: n/a
FF Driver: n/a
Device Name: Keyboard
Attached: 1
Controller ID: n/a
FF Driver: n/a
Device Name: Razer Mamba
Attached: 1
Controller ID: 0x0
Vendor/Product ID: 0x1532, 0x0024
FF Driver: n/a
Attached: 1
Controller ID: 0x0
FF Driver: n/a
Device Name: Razer Lycosa
Attached: 1
Controller ID: 0x0
Vendor/Product ID: 0x1532, 0x0109
FF Driver: n/a
Attached: 1
Controller ID: 0x0
FF Driver: n/a
Poll w/ Interrupt: No
USB Devices
+ USB Root Hub
| Vendor/Product ID: 0x8086, 0x2938
| Matching Device ID: usb\root_hub
| Service: usbhub
| Driver: usbhub.sys, 6/29/2013 13:07:15, 197632 bytes
| Driver: usbd.sys, 6/29/2013 13:06:53, 6016 bytes
Gameport Devices
PS/2 Devices
+ HID Keyboard Device
| Matching Device ID: hid_device_system_keyboard
| Service: kbdhid
| Driver: kbdhid.sys, 4/11/2009 15:38:40, 17408 bytes
| Driver: kbdclass.sys, 1/19/2008 00:41:54, 35384 bytes
| Service: kbdhid
+ Terminal Server Keyboard Driver
| Matching Device ID: root\rdp_kbd
| Upper Filters: kbdclass
| Service: TermDD
| Driver: i8042prt.sys, 1/18/2008 22:49:20, 54784 bytes
+ HID-compliant mouse
| Matching Device ID: hid_device_system_mouse
| Service: mouhid
| Driver: mouhid.sys, 1/18/2008 22:49:18, 15872 bytes
| Driver: mouclass.sys, 1/19/2008 00:41:54, 34360 bytes
+ Terminal Server Mouse Driver
| Matching Device ID: root\rdp_mou
| Upper Filters: mouclass
| Service: TermDD
| Driver: termdd.sys, 4/11/2009 17:32:52, 53224 bytes
| Driver: sermouse.sys, 1/18/2008 22:49:18, 19968 bytes
Disk & DVD/CD-ROM Drives
Drive: C:
Free Space: 108.8 GB
Total Space: 200.0 GB
File System: NTFS
Model: WDC WD7500AAKS-00RBA0 ATA Device
Drive: D:
Free Space: 249.9 GB
Total Space: 250.0 GB
File System: NTFS
Drive: E:
Free Space: 265.3 GB
Total Space: 265.4 GB
File System: NTFS
Drive: G:
Free Space: 24.3 GB
Total Space: 2861.5 GB
File System: NTFS
Model: ST3000DM001-9YN166 ATA Device
Drive: H:
Free Space: 2181.0 GB
File System: NTFS
Model: WDC WD30EZRX-00D8PB0 ATA Device
Drive: F:
Model: PIONEER DVD-RW DVR-215 ATA Device
Driver: c:\windows\system32\drivers\cdrom.sys, 6.00.6002.18005 (English), 4/11/2009 15:39:17, 67072 bytes
System Devices
Name: Intel(R) Management Engine Interface
Device ID: PCI\VEN_8086&DEV_29C4&SUBSYS_50448086&REV_02\3&18D45AA6&0&18
Driver: C:\Windows\system32\DRIVERS\HECI.sys, 3.00.0028.1060 (English), 3/13/2007 14:05:30, 44672 bytes
Name: Intel(R) G33/G31/P35 Express Chipset PCI Express Root Port - 29C1
Device ID: PCI\VEN_8086&DEV_29C1&SUBSYS_50448086&REV_02\3&18D45AA6&0&08
Driver: C:\Windows\system32\DRIVERS\pci.sys, 6.00.6002.18005 (English), 4/11/2009 17:32:55, 149480 bytes
Name: Intel(R) G33/G31/P35 Express Chipset Processor to I/O Controller - 29C0
Device ID: PCI\VEN_8086&DEV_29C0&SUBSYS_50448086&REV_02\3&18D45AA6&0&00
Driver: n/a
Name: Intel(R) 82566DC-2 Gigabit Network Connection
Device ID: PCI\VEN_8086&DEV_294C&SUBSYS_00018086&REV_02\3&18D45AA6&0&C8
Driver: C:\Windows\system32\DRIVERS\e1e6032.sys, 9.08.0020.0000 (English), 6/8/2007 13:59:05, 228224 bytes
Driver: C:\Windows\system32\Prounstl.exe, 9.01.0001.0000 (English), 6/8/2007 13:59:06, 154496 bytes
Driver: C:\Windows\system32\e1e6032.din, 6/8/2007 13:59:05, 2689 bytes
Driver: C:\Windows\system32\NicCo6.dll, 2.00.0001.0000 (English), 6/8/2007 13:59:05, 28536 bytes
Driver: C:\Windows\system32\NicInE6.dll, 9.08.0001.0000 (English), 6/8/2007 13:59:06, 39288 bytes
Driver: C:\Windows\system32\e1000msg.dll, 9.07.0000.0000 (English), 6/8/2007 13:59:04, 179048 bytes
Name: Intel(R) ICH9 Family PCI Express Root Port 5 - 2948
Device ID: PCI\VEN_8086&DEV_2948&SUBSYS_29488086&REV_02\3&18D45AA6&0&E4
Name: Intel(R) ICH9 Family PCI Express Root Port 4 - 2946
Device ID: PCI\VEN_8086&DEV_2946&SUBSYS_29468086&REV_02\3&18D45AA6&0&E3
Name: Intel(R) ICH9 Family PCI Express Root Port 3 - 2944
Device ID: PCI\VEN_8086&DEV_2944&SUBSYS_29448086&REV_02\3&18D45AA6&0&E2
Name: Intel(R) ICH9 Family PCI Express Root Port 2 - 2942
Device ID: PCI\VEN_8086&DEV_2942&SUBSYS_29428086&REV_02\3&18D45AA6&0&E1
Name: Intel(R) ICH9 Family PCI Express Root Port 1 - 2940
Device ID: PCI\VEN_8086&DEV_2940&SUBSYS_29408086&REV_02\3&18D45AA6&0&E0
Name: Intel(R) ICH9 Family USB2 Enhanced Host Controller - 293C
Device ID: PCI\VEN_8086&DEV_293C&SUBSYS_50448086&REV_02\3&18D45AA6&0&D7
Driver: C:\Windows\system32\drivers\usbehci.sys, 6.00.6002.18465 (English), 5/6/2011 00:54:07, 39936 bytes
Driver: C:\Windows\system32\drivers\usbport.sys, 6.00.6002.18875 (English), 6/29/2013 13:07:01, 226304 bytes
Driver: C:\Windows\system32\drivers\usbhub.sys, 6.00.6002.18875 (English), 6/29/2013 13:07:15, 197632 bytes
Driver: C:\Windows\system32\hccoin.dll, 6.00.6002.18465 (English), 5/6/2011 03:01:28, 8704 bytes
Driver: C:\Windows\system32\hcrstco.dll, 6.00.6002.18465 (English), 5/6/2011 03:01:28, 15872 bytes
Name: Intel(R) ICH9 Family USB2 Enhanced Host Controller - 293A
Device ID: PCI\VEN_8086&DEV_293A&SUBSYS_50448086&REV_02\3&18D45AA6&0&EF
Name: Intel(R) ICH9 Family USB Universal Host Controller - 2939
Device ID: PCI\VEN_8086&DEV_2939&SUBSYS_50448086&REV_02\3&18D45AA6&0&D2
Driver: C:\Windows\system32\drivers\usbuhci.sys, 6.00.6002.18465 (English), 5/6/2011 00:54:07, 23552 bytes
Name: Intel(R) ICH9 Family USB Universal Host Controller - 2938
Device ID: PCI\VEN_8086&DEV_2938&SUBSYS_50448086&REV_02\3&18D45AA6&0&D1
Name: Intel(R) ICH9 Family USB Universal Host Controller - 2937
Device ID: PCI\VEN_8086&DEV_2937&SUBSYS_50448086&REV_02\3&18D45AA6&0&D0
Name: Intel(R) ICH9 Family USB Universal Host Controller - 2936
Device ID: PCI\VEN_8086&DEV_2936&SUBSYS_50448086&REV_02\3&18D45AA6&0&EA
Name: Intel(R) ICH9 Family USB Universal Host Controller - 2935
Device ID: PCI\VEN_8086&DEV_2935&SUBSYS_50448086&REV_02\3&18D45AA6&0&E9
Name: Intel(R) ICH9 Family USB Universal Host Controller - 2934
Device ID: PCI\VEN_8086&DEV_2934&SUBSYS_50448086&REV_02\3&18D45AA6&0&E8
Name: Intel(R) ICH9 Family SMBus Controller - 2930
Device ID: PCI\VEN_8086&DEV_2930&SUBSYS_50448086&REV_02\3&18D45AA6&0&FB
Driver: n/a
Name: Intel(R) ICH9 2 port Serial ATA Storage Controller 2 - 2926
Device ID: PCI\VEN_8086&DEV_2926&SUBSYS_50448086&REV_02\3&18D45AA6&0&FD
Driver: C:\Windows\system32\DRIVERS\pciide.sys, 6.00.6002.18005 (English), 4/11/2009 17:32:49, 14312 bytes
Driver: C:\Windows\system32\DRIVERS\pciidex.sys, 6.00.6002.18005 (English), 4/11/2009 17:32:52, 43496 bytes
Driver: C:\Windows\system32\DRIVERS\atapi.sys, 6.00.6002.18005 (English), 4/11/2009 17:32:26, 19944 bytes
Driver: C:\Windows\system32\DRIVERS\ataport.sys, 6.00.6002.18005 (English), 4/11/2009 17:32:42, 109032 bytes
Name: Intel(R) ICH9 4 port Serial ATA Storage Controller 1 - 2920
Device ID: PCI\VEN_8086&DEV_2920&SUBSYS_50448086&REV_02\3&18D45AA6&0&FA
Name: PCI standard ISA bridge
Device ID: PCI\VEN_8086&DEV_2916&SUBSYS_50448086&REV_02\3&18D45AA6&0&F8
Driver: C:\Windows\system32\DRIVERS\msisadrv.sys, 6.00.6001.18000 (English), 1/19/2008 00:41:16, 16440 bytes
Name: Intel(R) 82801 PCI Bridge - 244E
Device ID: PCI\VEN_8086&DEV_244E&SUBSYS_50448086&REV_92\3&18D45AA6&0&F0
Name: Standard Dual Channel PCI IDE Controller
Device ID: PCI\VEN_11AB&DEV_6101&SUBSYS_610111AB&REV_B1\4&295D2893&0&00E1
Name: Creative SB X-Fi
Device ID: PCI\VEN_1102&DEV_000B&SUBSYS_00411102&REV_04\4&21263A0A&0&00E2
Driver: C:\Windows\system32\drivers\ctac32k.sys, 6.00.0001.1242 (English), 4/21/2009 04:31:34, 511000 bytes
Driver: C:\Windows\system32\drivers\ctaud2k.sys, 6.00.0001.1347 (English), 4/21/2009 04:31:44, 536344 bytes
Driver: C:\Windows\system32\drivers\ctoss2k.sys, 6.00.0001.1347 (English), 4/21/2009 04:32:28, 129560 bytes
Driver: C:\Windows\system32\drivers\ctprxy2k.sys, 6.00.0001.1347 (English), 4/21/2009 04:32:38, 14360 bytes
Driver: C:\Windows\system32\drivers\ctsfm2k.sys, 6.00.0001.1347 (English), 4/21/2009 04:36:44, 159256 bytes
Driver: C:\Windows\system32\drivers\emupia2k.sys, 6.00.0001.1347 (English), 4/21/2009 04:36:56, 95768 bytes
Driver: C:\Windows\system32\drivers\ha20x2k.sys, 6.00.0001.1347 (English), 4/21/2009 04:37:08, 1180696 bytes
Driver: C:\Windows\system32\drivers\ha20x22k.sys, 6.00.0001.1347 (English), 4/21/2009 04:37:26, 1223192 bytes
Driver: C:\Windows\system32\drivers\pfmodnt.sys, 3.00.0000.0012 (English), 4/21/2009 04:37:36, 15384 bytes
Driver: C:\Windows\system32\drivers\CTEXFIFX.sys, 6.00.0001.1347 (English), 4/21/2009 04:31:24, 1353240 bytes
Driver: C:\Windows\system32\drivers\CT20XUT.sys, 6.00.0001.1347 (English), 4/21/2009 04:26:56, 198168 bytes
Driver: C:\Windows\system32\drivers\CTHWIUT.sys, 6.00.0001.1347 (English), 4/21/2009 04:31:12, 73752 bytes
Driver: C:\Windows\system32\drivers\ct20xflt.sys, 5.10.0000.4314 (English), 4/21/2009 04:37:50, 1811096 bytes
Driver: C:\Windows\system32\ctdlang.dat, 4/21/2009 02:27:30, 51787 bytes
Driver: C:\Windows\system32\ctdnlstr.dat, 4/21/2009 02:27:30, 384428 bytes
Driver: C:\Windows\system32\CtxfiRes.dll, 6.00.0001.1347 (English), 4/21/2009 02:38:56, 2560 bytes
Driver: C:\Windows\system32\ctzapxx.ini, 4/21/2009 03:09:46, 54 bytes
Driver: C:\Windows\system32\instwdm.ini, 4/21/2009 03:09:46, 16563 bytes
Driver: C:\Windows\system32\CT1MGM.ROM, 2/26/2000 02:49:36, 1048576 bytes
Driver: C:\Windows\system32\CT2MGM.SF2, 9/23/1999 13:18:38, 2167684 bytes
Driver: C:\Windows\system32\default4.sfm, 1/4/2002 05:44:16, 59 bytes
Driver: C:\Windows\system32\default8.sfm, 1/4/2002 05:44:16, 59 bytes
Driver: C:\Windows\system32\default.sfm, 1/4/2002 05:44:16, 59 bytes
Driver: C:\Windows\Temp\ctpxst32.exe, 1.01.0000.0059 (English), 3/14/2007 00:32:14, 89336 bytes
Driver: C:\Windows\Temp\cttele32.dll, 1.00.0019.0000 (English), 2/18/2009 07:33:22, 106496 bytes
Driver: C:\Windows\system32\regplib.exe, 4/21/2009 02:23:30, 16384 bytes
Driver: C:\Windows\system32\a3d.dll, 80.00.0000.0003 (English), 4/21/2009 02:40:28, 14336 bytes
Driver: C:\Windows\system32\ac3api.dll, 6.00.0001.1347 (English), 4/21/2009 02:39:44, 13312 bytes
Driver: C:\Windows\system32\eaxac3.dll, 1.01.0002.0000 (English), 7/12/2001 00:51:00, 77824 bytes
Driver: C:\Windows\system32\ctosuser.dll, 6.00.0001.1347 (English), 4/21/2009 02:23:44, 74240 bytes
Driver: C:\Windows\system32\ctemupia.dll, 6.00.0001.1347 (English), 4/21/2009 02:27:00, 201216 bytes
Driver: C:\Windows\system32\piaproxy.dll, 6.00.0001.1347 (English), 4/21/2009 02:23:26, 68608 bytes
Driver: C:\Windows\system32\ctdproxy.dll, 6.00.0001.1347 (English), 4/21/2009 02:24:22, 53248 bytes
Driver: C:\Windows\system32\devreg.dll, 6.00.0001.1347 (English), 4/21/2009 02:19:50, 36864 bytes
Driver: C:\Windows\system32\ctasio.dll, 6.00.0001.1347 (English), 4/21/2009 02:24:24, 50688 bytes
Driver: C:\Windows\system32\ct_oal.dll, 6.00.0001.1347 (English), 4/21/2009 02:24:26, 193024 bytes
Driver: C:\Windows\system32\ctpxst32.exe, 1.01.0000.0059 (English), 3/14/2007 00:32:14, 89336 bytes
Driver: C:\Windows\system32\APOIM32.exe, 2.47.0000.0000 (English), 3/27/2009 06:09:18, 600217 bytes
Driver: C:\Windows\system32\oalinst.exe, 2.00.0006.0000 (English), 4/23/2008 20:07:52, 805400 bytes
Driver: C:\Windows\system32\AddCat.exe, 0.00.0000.0001 (English), 12/6/2006 04:52:40, 48400 bytes
Driver: C:\Windows\system32\UDAAPO32.UDA, 2/6/2009 08:32:00, 7974 bytes
Driver: C:\Windows\system32\UDACFX32.UDA, 4/16/2009 06:26:24, 6342 bytes
Driver: C:\Windows\system32\CTMLFX32.UDA, 6/3/2008 01:10:06, 5458 bytes
Driver: C:\Windows\system32\CTxfiBtn.dll, 6.00.0001.1347 (English), 4/21/2009 02:38:56, 42496 bytes
Driver: C:\Windows\system32\CTxfiSpk.dll, 6.00.0001.1347 (English), 4/21/2009 02:38:54, 39424 bytes
Driver: C:\Windows\system32\Ct20xspi.dll, 6.00.0001.1347 (English), 4/21/2009 02:34:34, 15360 bytes
Driver: C:\Windows\system32\CTxfispi.exe, 6.00.0001.1347 (English), 4/21/2009 02:34:28, 1263104 bytes
Driver: C:\Windows\system32\Ctxfihlp.exe, 6.00.0001.1347 (English), 4/21/2009 02:38:52, 24576 bytes
Driver: C:\Windows\system32\CTxfiReg.exe, 6.00.0001.1347 (English), 4/21/2009 02:34:38, 47104 bytes
Driver: C:\Windows\system32\enlocstr.exe, 4/21/2009 02:20:24, 7680 bytes
Driver: C:\Windows\system32\killapps.exe, 1.00.0000.0001 (English), 4/21/2009 02:20:18, 12800 bytes
Driver: C:\Windows\system32\kill.ini, 8/20/2008 08:40:02, 321 bytes
Driver: C:\Windows\system32\sfman32.dll, 6.00.0001.1347 (English), 4/21/2009 02:23:42, 10240 bytes
Driver: C:\Windows\system32\sfms32.dll, 6.00.0001.1347 (English), 4/21/2009 02:23:38, 130560 bytes
Driver: C:\Windows\system32\data\cts20x.dat, 4/21/2009 02:20:28, 2091 bytes
Driver: C:\Windows\system32\data\ctd20x.dat, 4/21/2009 02:20:28, 42287 bytes
Driver: C:\Windows\system32\data\CTP0880W.DAT, 4/21/2009 02:22:54, 302878 bytes
Driver: C:\Windows\system32\data\CTP0882W.DAT, 4/21/2009 02:22:54, 302878 bytes
Driver: C:\Windows\system32\data\CTP0886W.DAT, 4/21/2009 02:22:56, 302878 bytes
Driver: C:\Windows\system32\data\CTP0883W.DAT, 4/21/2009 02:22:56, 302878 bytes
Driver: C:\Windows\system32\data\CTP0889W.DAT, 4/21/2009 02:22:56, 302878 bytes
Driver: C:\Windows\system32\data\CTP0888W.DAT, 4/21/2009 02:22:58, 302878 bytes
Driver: C:\Windows\system32\data\CTP0881W.DAT, 4/21/2009 02:22:58, 302878 bytes
Driver: C:\Windows\system32\data\CTP0880V.DAT, 4/21/2009 02:23:14, 413708 bytes
Driver: C:\Windows\system32\data\CTP0882V.DAT, 4/21/2009 02:23:14, 413708 bytes
Driver: C:\Windows\system32\data\CTP0886V.DAT, 4/21/2009 02:23:16, 413708 bytes
Driver: C:\Windows\system32\data\CTP0883V.DAT, 4/21/2009 02:23:16, 413708 bytes
Driver: C:\Windows\system32\data\CTP0889V.DAT, 4/21/2009 02:23:18, 413708 bytes
Driver: C:\Windows\system32\data\CTP0888V.DAT, 4/21/2009 02:23:20, 413708 bytes
Driver: C:\Windows\system32\data\CTP0881V.DAT, 4/21/2009 02:23:20, 413708 bytes
Driver: C:\Windows\system32\data\CTXFIGM.RFX, 10/16/2007 05:01:52, 56192 bytes
Driver: C:\Windows\system32\data\CTXFIEM.RFX, 10/16/2007 05:01:52, 56660 bytes
Driver: C:\Windows\system32\data\CTXFICM.RFX, 4/9/2008 08:23:04, 56592 bytes
Driver: C:\Windows\system32\data\CTXFICBM.RFX, 6/23/2005 20:58:50, 7352 bytes
Driver: C:\Windows\system32\SBXFi.ico, 2/5/2008 05:32:50, 5430 bytes
Driver: C:\Windows\system32\XFi.bmp, 2/5/2008 05:32:50, 1688 bytes
Driver: C:\Windows\system32\ctcoinst.dll, 3.00.0002.0051 (English), 4/21/2009 02:42:06, 86016 bytes
Driver: C:\Windows\system32\ctdvinst.dll, 0.05.0000.0051 (English), 4/21/2009 02:42:08, 181248 bytes
Driver: C:\Windows\system32\UDAAPO32.dll, 1.00.0002.0000 (English), 1/22/2009 06:42:40, 498176 bytes
Driver: C:\Windows\system32\UDAPLD32.dll, 1.00.0002.0000 (English), 1/22/2009 06:43:02, 47104 bytes
Driver: C:\Windows\system32\UDACFX32.dll, 1.01.0000.0045 (English), 4/16/2009 01:10:52, 216064 bytes
Driver: C:\Windows\system32\CTMLFX32.dll, 1.00.0004.0000 (English), 6/2/2008 23:40:22, 62976 bytes
Driver: C:\Windows\system32\drivers\drmk.sys, 6.00.6002.18974 (English), 10/30/2013 12:43:04, 130048 bytes
Driver: C:\Windows\system32\drivers\portcls.sys, 6.00.6002.18974 (English), 10/30/2013 11:43:06, 167936 bytes
Driver: C:\Windows\system32\WMALFXGFXDSP.dll, 11.00.6002.18974 (English), 10/30/2013 13:13:01, 1304064 bytes
Driver: C:\Windows\system32\SysFxUI.dll, 6.00.6002.18974 (English), 10/30/2013 13:12:54, 335360 bytes
Name: NVIDIA GeForce GTX 550 Ti
Device ID: PCI\VEN_10DE&DEV_1244&SUBSYS_351A1458&REV_A1\4&727DAF7&0&0008
Driver: C:\Program Files\NVIDIA Corporation\Drs\dbInstaller.exe, 9.18.0013.4709 (English), 12/13/2014 21:02:10, 385344 bytes
Driver: C:\Program Files\NVIDIA Corporation\Drs\nvdrsdb.bin, 12/13/2014 21:02:10, 1246120 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_91dcbb86\NvCplSetupInt.exe, 1.00.0004.0000 (English), 12/13/2014 21:02:10, 82608448 bytes
Driver: C:\Program Files\NVIDIA Corporation\license.txt, 7/3/2014 07:54:57, 21904 bytes
Driver: C:\Program Files\NVIDIA Corporation\OpenCL\OpenCL.dll, 1.00.0000.0000 (English), 12/13/2014 21:02:10, 60560 bytes
Driver: C:\Windows\system32\DRIVERS\nvlddmkm.sys, 9.18.0013.4709 (English), 12/13/2014 21:02:10, 8536208 bytes
Driver: C:\Windows\system32\nvapi.dll, 9.18.0013.4709 (English), 12/13/2014 21:02:10, 2897640 bytes
Driver: C:\Windows\system32\nvcompiler.dll, 8.17.0013.4709 (English), 12/13/2014 21:02:10, 20465808 bytes
Driver: C:\Windows\system32\nvcuda.dll, 8.17.0013.4709 (English), 12/13/2014 21:02:10, 10710344 bytes
Driver: C:\Windows\system32\nvcuvid.dll, 7.17.0013.4709 (English), 12/13/2014 21:02:10, 3249984 bytes
Driver: C:\Windows\system32\nvd3dum.dll, 9.18.0013.4709 (English), 12/13/2014 21:02:10, 14128496 bytes
Driver: C:\Windows\system32\nvinfo.pb, 12/13/2014 21:02:10, 22896 bytes
Driver: C:\Windows\system32\nvoglv32.dll, 9.18.0013.4709 (English), 12/13/2014 21:02:10, 24764048 bytes
Driver: C:\Windows\system32\nvopencl.dll, 8.17.0013.4709 (English), 12/13/2014 21:02:10, 10771128 bytes
Driver: C:\Windows\system32\nvwgf2um.dll, 9.18.0013.4709 (English), 12/13/2014 21:02:10, 16039176 bytes
Driver: C:\Windows\system32\nvdispco3234709.dll, 2.00.0041.0004 (English), 12/13/2014 21:02:10, 1047696 bytes
Driver: C:\Windows\system32\nvdispgenco3234709.dll, 2.00.0019.0002 (English), 12/13/2014 21:02:10, 911504 bytes
Name: High Definition Audio Controller
Device ID: PCI\VEN_10DE&DEV_0BEE&SUBSYS_351A1458&REV_A1\4&727DAF7&0&0108
Driver: C:\Windows\system32\DRIVERS\hdaudbus.sys, 6.00.6002.18005 (English), 4/11/2009 15:42:42, 561152 bytes
DirectShow Filters
DirectShow Filters:
WMAudio Decoder DMO,0x00800800,1,1,,
WMAPro over S/PDIF DMO,0x00600800,1,1,,
WMSpeech Decoder DMO,0x00600800,1,1,,
MP3 Decoder DMO,0x00600800,1,1,,
Mpeg4s Decoder DMO,0x00800001,1,1,,
WMV Screen decoder DMO,0x00600800,1,1,,
WMVideo Decoder DMO,0x00800001,1,1,,
Mpeg43 Decoder DMO,0x00800001,1,1,,
Mpeg4 Decoder DMO,0x00800001,1,1,,
Full Screen Renderer,0x00200000,1,0,,6.06.6002.18725
Multiple File Output,0x00200000,2,2,WMM2FILT.dll,
CT Upsampler filter,0x00100000,1,1,Upsample.ax,2.00.0005.0000
WMT Black Frame Generator,0x00200000,1,1,WMM2FILT.dll,
WMT Import Filter,0x00200000,0,1,WMM2FILT.dll,
Creative Wave Writer,0x00200000,1,0,WavWrite.ax,3.01.0004.0000
DV Muxer,0x00400000,0,0,,6.06.6001.18000
Color Space Converter,0x00400001,1,1,,6.06.6002.18725
WMT Interlacer,0x00200000,1,1,WMM2FILT.dll,
WM ASF Reader,0x00400000,0,0,,11.00.6001.7000
Screen Capture filter,0x00200000,0,1,wmpsrcwp.dll,11.00.6001.7000
AVI Splitter,0x00600000,1,1,,6.06.6002.18725
VGA 16 Color Ditherer,0x00400000,1,1,,6.06.6002.18725
Microsoft MPEG-2 Video Decoder,0x005fffff,2,4,msmpeg2vdec.dll,11.00.6001.7110
BPM Metadata,0x001fffff,1,1,MetaBPMu.ax,2.00.0002.0000
Creative Recording Wav_Asio Filter,0x00400000,0,1,AudioRec.ax,1.00.0002.0000
AC3 Parser Filter,0x00600000,1,1,mpg2splt.ax,6.06.6002.18363
WMT Format Conversion,0x00200000,1,1,WMM2FILT.dll,
9x8Resize,0x00200000,1,1,WMM2FILT.dll,
CT Time-Scaling filter,0x00100000,1,1,TimeScal.ax,2.03.0009.0000
StreamBufferSink,0x00200000,0,0,sbe.dll,6.06.6002.18363
WMT Virtual Source,0x00200000,0,1,WMM2FILT.dll,
Microsoft TV Caption Decoder,0x00200001,1,0,MSTVCapn.dll,6.00.6002.18536
MJPEG Decompressor,0x00600000,1,1,,6.06.6002.18725
CBVA DMO wrapper filter,0x00200000,1,1,cbva.dll,6.00.6002.18242
MPEG-I Stream Splitter,0x00600000,1,2,,6.06.6002.18725
SAMI (CC) Parser,0x00400000,1,1,,6.06.6002.18725
VBI Codec,0x00600000,1,4,VBICodec.ax,6.06.6001.18000
MPEG-2 Splitter,0x005fffff,1,0,mpg2splt.ax,6.06.6002.18363
WMT AudioAnalyzer,0x00200000,1,1,WMM2FILT.dll,
Microsoft MPEG-2 Video Encoder,0x00200000,2,0,msmpeg2enc.dll,11.00.6001.7000
Stretch Video,0x00200000,1,1,WMM2FILT.dll,
Internal Script Command Renderer,0x00800001,1,0,,6.06.6002.18725
MPEG Audio Decoder,0x03680001,1,1,,6.06.6002.18725
DV Splitter,0x00600000,1,2,,6.06.6001.18000
Video Mixing Renderer 9,0x00200000,1,0,,6.06.6002.18725
CT Karaoke filter,0x00100000,1,1,Karaoke.ax,2.00.0012.0000
Microsoft MPEG-2 Encoder,0x00200000,2,1,msmpeg2enc.dll,11.00.6001.7000
Frame Eater,0x00200000,1,1,WMM2FILT.dll,
Creative AC3 Source Filter,0x00400000,0,1,AC3Srcu.ax,3.02.0001.0000
Creative PCM Raw Writer,0x00200000,1,0,RawWritu.ax,1.00.0000.0000
Allocator Fix,0x00200000,1,1,WMM2FILT.dll,
CT PDP filter,0x00100000,1,1,PDP.ax,1.00.0008.0000
ACM Wrapper,0x00600000,1,1,,6.06.6002.18725
Video Renderer,0x00800001,1,0,,6.06.6002.18725
MPEG-2 Video Stream Analyzer,0x00200000,0,0,sbe.dll,6.06.6002.18363
Capture ASF Writer,0x00200000,0,0,WMM2FILT.dll,
Line 21 Decoder,0x00600000,1,1,,6.06.6002.18533
Video Port Manager,0x00600000,2,1,,6.06.6002.18725
Video Renderer,0x00400000,1,0,,6.06.6002.18725
Bitmap Generate,0x00200000,1,1,WMM2FILT.dll,
Proxy Sink,0x00200000,1,0,WMM2FILT.dll,
Proxy Source,0x00200000,0,1,WMM2FILT.dll,
CT SmartVolumeManagement filter,0x00100000,1,1,DSCompr.ax,1.00.0008.0000
Creative Audio Gain Filter,0x00200000,1,1,AudGain.ax,1.00.0000.0000
WM ASF Writer,0x00400000,0,0,,11.00.6001.7000
VBI Surface Allocator,0x00600000,1,1,vbisurf.ax,6.00.6001.18000
Creative Flac Source Filter,0x00400000,0,1,FlacSrcu.ax,1.00.0002.0000
WMT Sample Information Filter,0x00200000,1,1,WMM2FILT.dll,
File writer,0x00200000,1,0,,6.06.6001.18000
Creative MLP Source Filter,0x00400000,0,1,MlpSrcu.ax,3.01.0000.0000
Creative File Reader Filter,0x00400000,0,1,FilReadu.ax,1.00.0005.0000
SVM Metadata,0x001fffff,1,1,MetaSVMu.ax,2.00.0002.0000
CT HPVirtualizer filter,0x00100000,1,1,Virtual.ax,1.00.0000.0000
WAV Dest,0x00000000,0,0,,
DVD Navigator,0x00200000,0,3,,6.06.6002.18533
WMT DV Extract,0x00200000,1,1,WMM2FILT.dll,
Overlay Mixer2,0x00200000,1,1,,6.06.6002.18533
CT CMSS3 filter,0x00100000,1,1,CMSS3.ax,3.00.0013.0000
AVI Draw,0x00600064,9,1,,6.06.6002.18725
Microsoft MPEG-2 Audio Encoder,0x00200000,2,0,msmpeg2enc.dll,11.00.6001.7000
WST Pager,0x00800000,1,1,WSTPager.ax,6.06.6001.18000
MPEG-2 Demultiplexer,0x00600000,1,1,mpg2splt.ax,6.06.6002.18363
Record Queue,0x00200000,1,1,WMM2FILT.dll,
Creative Ogg Source Filter,0x00400000,0,1,OggSrcu.ax,1.00.0001.0000
DV Video Decoder,0x00800000,1,1,,6.06.6001.18000
Creative NVF Filter,0x00400000,0,1,NvfSrcu.ax,3.01.0001.0000
Noise Reduction,0x00100000,1,1,NoisRedu.ax,3.00.0007.0000
SampleGrabber,0x00200000,1,1,qedit.dll,6.06.6002.19118
Null Renderer,0x00200000,1,0,qedit.dll,6.06.6002.19118
WMT Log Filter,0x00200000,1,1,WMM2FILT.dll,
Creative WMA Writer,0x00200000,1,0,WMAWrite.ax,5.00.0001.0000
MPEG-2 Sections and Tables,0x005fffff,1,0,Mpeg2Data.ax,6.06.6002.18496
Microsoft AC3 Encoder,0x00200000,1,1,msac3enc.dll,11.00.6001.7000
WMT Virtual Renderer,0x00200000,1,0,WMM2FILT.dll,
StreamBufferSource,0x00200000,0,0,sbe.dll,6.06.6002.18363
Smart Tee,0x00200000,1,2,,6.06.6001.18000
Creative WMA Source Filter,0x00400000,0,1,WmaSrc.ax,3.01.0001.0000
Overlay Mixer,0x00200000,0,0,,6.06.6002.18533
AVI Decompressor,0x00600000,1,1,,6.06.6002.18725
WMT MuxDeMux Filter,0x00200000,0,0,WMM2FILT.dll,
NetBridge,0x00200000,2,0,netbridge.dll,6.01.6001.18000
AVI/WAV File Source,0x00400000,0,2,,6.06.6002.18725
WMT Volume,0x00200000,1,1,WMM2FILT.dll,
Wave Parser,0x00400000,1,1,,6.06.6002.18725
MIDI Parser,0x00400000,1,1,,6.06.6002.18725
Multi-file Parser,0x00400000,1,1,,6.06.6002.18725
File stream renderer,0x00400000,1,1,,6.06.6002.18725
WMT VIH2 Fix,0x00200000,1,1,WMM2FILT.dll,
Microsoft MPEG-1/DD Audio Decoder,0x005fffff,1,1,msmpeg2adec.dll,11.00.6001.7000
AVI Mux,0x00200000,1,0,,6.06.6001.18000
Line 21 Decoder 2,0x00600002,1,1,,6.06.6002.18725
File Source (Async.),0x00400000,0,1,,6.06.6002.18725
File Source (URL),0x00400000,0,1,,6.06.6002.18725
Media Center Extender Encryption Filter,0x00200000,2,2,Mcx2Filter.dll,6.01.6002.18005
AudioRecorder WAV Dest,0x00200000,0,0,,6.00.6001.18000
AudioRecorder Wave Form,0x00200000,0,0,,6.00.6001.18000
SoundRecorder Null Renderer,0x00200000,0,0,,6.00.6001.18000
Creative CDDA Source Filter,0x00400000,0,1,CDDA.ax,3.00.0003.0000
Creative LiveRecording Filter SxS,0x00400000,0,1,LiveRecu.ax,5.00.0001.0000
Creative Internet Source Filter,0x00400000,0,1,InetSrcu.ax,1.00.0000.0000
Infinite Pin Tee Filter,0x00200000,1,1,,6.06.6001.18000
WMT Switch Filter,0x00200000,1,1,WMM2FILT.dll,
Enhanced Video Renderer,0x00200000,1,0,evr.dll,6.00.6002.18005
Uncompressed Domain Shot Detection Filter,0x00200000,1,1,WMM2FILT.dll,
BDA MPEG2 Transport Information Filter,0x00200000,2,0,psisrndr.ax,6.06.6002.18496
MPEG Video Decoder,0x40000001,1,1,,6.06.6002.18725
WDM Streaming Tee/Splitter Devices:
Tee/Sink-to-Sink Converter,0x00200000,1,1,,6.00.6001.18000
WDM Streaming Data Transforms:
Microsoft Kernel DRM Audio Descrambler,0x00200000,1,1,,6.00.6001.18000
Video Compressors:
WMVideo8 Encoder DMO,0x00600800,1,1,,
WMVideo9 Encoder DMO,0x00600800,1,1,,
MSScreen 9 encoder DMO,0x00600800,1,1,,
DV Video Encoder,0x00200000,0,0,,6.06.6001.18000
MJPEG Compressor,0x00200000,0,0,,6.06.6002.18725
Cinepak Codec by Radius,0x00200000,1,1,,6.06.6001.18000
Action! Video Decompressor,0x00000000,0,0,,
Intel IYUV codec,0x00200000,1,1,,6.06.6001.18000
Microsoft RLE,0x00200000,1,1,,6.06.6001.18000
Microsoft Video 1,0x00200000,1,1,,6.06.6001.18000
Audio Compressors:
WM Speech Encoder DMO,0x00600800,1,1,,
WMAudio Encoder DMO,0x00600800,1,1,,
IMA ADPCM,0x00200000,1,1,,6.06.6002.18725
Microsoft ADPCM,0x00200000,1,1,,6.06.6002.18725
GSM 6.10,0x00200000,1,1,,6.06.6002.18725
CCITT A-Law,0x00200000,1,1,,6.06.6002.18725
CCITT u-Law,0x00200000,1,1,,6.06.6002.18725
MPEG Layer-3,0x00200000,1,1,,6.06.6002.18725
Audio Capture Sources:
Microphone (2- Razer Megalodon),0x00200000,0,0,,6.06.6001.18000
"What U Hear" (Creative SB X-Fi,0x00200000,0,0,,6.06.6001.18000
Digital-In (Creative SB X-Fi),0x00200000,0,0,,6.06.6001.18000
Midi Renderers:
Default MidiOut Device,0x00800000,1,0,,6.06.6002.18725
Microsoft GS Wavetable Synth,0x00200000,1,0,,6.06.6002.18725
SB X-Fi Synth A [0001],0x00200000,1,0,,6.06.6002.18725
SB X-Fi Synth B [0001],0x00200000,1,0,,6.06.6002.18725
WDM Streaming Capture Devices:
Digital-In,0x00000000,0,0,,
Microphone FP,0x00000000,0,0,,
Line-In,0x00000000,0,0,,
,0x00000000,0,0,,
SB X-Fi Audio [0001],0x00200000,1,1,,6.00.6001.18000
SB Live!2K Audio [0001],0x00000000,0,0,,
USB Audio Device,0x00200000,2,2,,6.00.6001.18000
WDM Streaming Rendering Devices:
,0x00000000,0,0,,
,0x00000000,0,0,,
,0x00000000,0,0,,
SB X-Fi SpdifOut [0001],0x00000000,0,0,,
SB X-Fi Synth A [0001],0x00200000,1,1,,6.00.6001.18000
SB X-Fi Synth B [0001],0x00200000,1,1,,6.00.6001.18000
,0x00000000,0,0,,
BDA Network Providers:
Microsoft ATSC Network Provider,0x00200000,0,1,MSDvbNP.ax,6.06.6002.18496
Microsoft DVBC Network Provider,0x00200000,0,1,MSDvbNP.ax,6.06.6002.18496
Microsoft DVBS Network Provider,0x00200000,0,1,MSDvbNP.ax,6.06.6002.18496
Microsoft DVBT Network Provider,0x00200000,0,1,MSDvbNP.ax,6.06.6002.18496
Microsoft Network Provider,0x00200000,0,1,MSNP.ax,6.06.6002.18005
Multi-Instance Capable VBI Codecs:
BDA Transport Information Renderers:
BDA MPEG2 Transport Information Filter,0x00600000,2,0,psisrndr.ax,6.06.6002.18496
MPEG-2 Sections and Tables,0x00600000,1,0,Mpeg2Data.ax,6.06.6002.18496
BDA CP/CA Filters:
Decrypt/Tag,0x00600000,1,0,EncDec.dll,6.06.6002.18528
Encrypt/Tag,0x00200000,0,0,EncDec.dll,6.06.6002.18528
XDS Codec,0x00200000,0,0,EncDec.dll,6.06.6002.18528
WDM Streaming Communication Transforms:
Audio Renderers:
Speakers (2- Razer Megalodon),0x00200000,1,0,,6.06.6002.18725
Default DirectSound Device,0x00800000,1,0,,6.06.6002.18725
Default WaveOut Device,0x00200000,1,0,,6.06.6002.18725
DirectSound: SPDIF Out (Creative SB X-Fi),0x00200000,1,0,,6.06.6002.18725
DirectSound: Speakers (2- Razer Megalodon),0x00200000,1,0,,6.06.6002.18725
DirectSound: Speakers (Creative SB X-Fi),0x00200000,1,0,,6.06.6002.18725
cherbz
Fri Jan 23, 2015 9:54 am
Bump
blancjoker
PC Specification: I7-4770k, GTX780ti, Window 8.1/7
Mon Feb 02, 2015 8:21 pm
Turn off one of your monitors before starting up action. Once Action has started, re-plug in your second monitor. It works every time for me.
