ratzoh
PC Specification: Phenom X6 3.6GHz 1100T, NVIDIA GT570 SLi
Problem with Mirillis recording at all.
Sun Jan 11, 2015 3:47 pm
OS: Windows 7
Video Card: GT580 NVIDIA
Memory: 16 GB
Monitor Resolution: 1680x1050
Game Problem: S.K.I.L.L SF2
Video Type: Both avi and mp4
Mirillis doesnt recognize my game after the latest patch. Any info you need?
http://i.imgur.com/zr0LPUv.png
The record thingie is grey. My routine to launch it is first launching mirillis as admin then my game as admin - now it doesnt work anymore. Did try with launching the same way CS:GO same result.
AJLefty015
PC Specification: ASUS Q550lf
Re: Problem with Mirillis recording at all.
Mon Jan 12, 2015 10:46 pm
This happens to me to. Just go onto your game with a full screen mode and press your recording hotkey. It will start recording when you press this. Unless you changed your hot key it will be f9.
