We would like to ask for some more info about the problem:Mbah Surip wrote:nah, i had already used them, and both of them make the video looks nasty
I solved the problem by using latest ffdshow. You did the same?denleon wrote:Was the same problem.The same way-ffdshow.
Yes.rev3154.Others didnt try.I solved the problem by using latest ffdshow. You did the same?
