SuperRobbieCraft
PC Specification: Windows 1.8
Capture Card Recording Not Working
Tue Jan 13, 2015 2:25 am
I recently Bought a capture card (Diamond Multimedia GC500) and tried to record it. On the computer screen it showed it was coming out good. When I finally finished recording I replayed the recording on the Main Menu. What showed up was a Big black box. The Capture Card's thing did not show up but turned into the black box. Does anyone know how to fix this or why its happening? Plz Help Thanks For Looking And Bye.
SuperRobbieCraft
Re: Capture Card Recording Not Working
Thu Feb 05, 2015 3:57 pm
Plz help i git this capture card about a month ago
DIGG
Thu Feb 05, 2015 5:12 pm
Why not use a specific software to record with your device? Action! isn't meant to be use to capture the output of the capturing software, per say. Also what could be wrong for you is that your capturing software is outputing the video through a video renderer which Action! can't record. Most recording software outputs their video with the EVR renderer, which can't be captured "on screen" with Action!. Check your software and see if you can change the video renderer to something else (Overlay Mixer might work, or maybe VMR 9).
But your main problem is not with Action!, it's with your recording software in the first place.
SuperRobbieCraft
Tue Mar 03, 2015 6:33 am
Thankd Very Much Ill Try That Later! (; :D
