Cryptic
PC Specification: i5 3570K GTX 660 TI Windows 8.1
Mousecursor Bug
Fri Jan 16, 2015 1:19 pm
Hello to all who will read this.
I would like to briefly describe my problem. Recently, there is a problem with the recordings. Whenever I stop the recording and try to watch it, the cursor stucks. ( I have attached a picture..)
At the moment I use the latest version of Action (1.20.2.0) and Windows 8.1. Maybe this could be the problem, but I'm not sure, that's why I hope you could help me, thank you! :D
Solution found! You have to install the newest Version of Action. It fixes this bug! :D
Cursor stucks, while I "click" options
Re: Mousecursor Bug
Fri Jan 16, 2015 4:19 pm
Do you record using Game/Application or Screen Mode?
Cryptic
Re: Mousecursor Bug
Fri Jan 16, 2015 10:36 pm
radi wrote:Do you record using Game/Application or Screen Mode?
I have used Game Mode^^
