hectorbarbosa1
PC Specification: windows 7, i7 3770, gtx 660
Action forcing changes with windows/other programs
Sat Jan 17, 2015 8:12 am
Hi guys, I have been using action for a while now, but recently and I have no clue why it has ended up having a strange glitch, I use Action along with audacity to record gameplay/desktop and commentary
I would open both programs, hit record on audacity (with input recording volume set to around 0.4), then open the game and start recording with Action, and it would all go good and I'd sync it up later, I'd been doing this for months with no issues.
Yet recently for some reason when I click start recording with Action the input recording slider on audacity will suddenly jump on it's own to 0.9... (whether it's already recording audio or not it still changes) which then makes my commentary max out too much, then when I stop recording again it goes back to my setting at 0.4... WTH?, it also doesn't matter which hotkey I change Action to start recording with it still triggers anyway as soon as it starts/stops recording the screen/game.
I can't find any setting relating to locking the input recording volume in audacity or any other settings to stop this from happening..
Why is action causing audacity to do this?
I did find that if I disable "record system sounds" on Action it no longer causes the audacity slider adjustment when screen recording starts, so it has to be related to a conflict with that somewhere :/ I just dunno how to fix it
I have also contacted the audacity guys but they said it sounds more like an issue with Action so that I should contact you guys
I am using windows 7 too
Thanks for any help guys
Re: Action forcing changes with windows/other programs
Tue Jan 20, 2015 2:06 pm
Please report your issue to our support team via support@mirillis.com They will investigate your issue.
