mjarret1
PC Specification: 8.1
Will not record Direct to Oculus Rift
Sun Jan 18, 2015 5:29 pm
OS: windows 8.1
Video Card: AMD R9 270X
Memory: 8 GB
Monitor Resolution: 1920 x 1080
Video Editor: None
Game Problem: Diplopia (on Oculus Rift)
Video Type: MP4 (or any other video type)
I -was- able to record the game "Diplopia" using the Oculus Rift in "direct to Rift mode"
The game "normally" will display on the Oculus Rift -or- on the Monitor....not both at the same time.
I -was- able to upload the video file that was created on to YouTube.
Then the "Diplopia" game came out with an updated version.
Now the game cannot be recorded in the "direct to Rift mode".
The game still plays perfectly in the "direct to Rift mode"
However if you start the game in "direct to rift" mode no recording can be made by Action Mirillis.
If you start the game in the “direct to rift” mode -and- in the "monitor” mode at the same time; the "direct to rift" mode will lock up.
You can record from the monitor... but in the game "Diplopia" the monitor mode is useless for trying to actually play the game.
The developer of the game does not know what would cause Mirillis not to record properly ...at this time.
Other Oculus Rift games that I have are still able to be recorded in the "direct to Rift mode"
Please help if you know what could be causing this problem since I originally found your software
easy to use and would like to purchase Action Mirillis.
Re: Will not record Direct to Oculus Rift
Tue Jan 20, 2015 2:01 pm
Please report your issue to our support team. They will investigate your issue closer.
Users browsing this forum: No registered users and 55 guests
