TheRA1DER
PC Specification: ASROCK Z77 PRO3+HD6970+i7-3770K+Win 7x64
Mirillis Crashed = video file corrupted
Thu Jan 29, 2015 1:14 pm
OS: Windows 8.1 x64
Video Card: Intel 780
Memory: 8 GB DDR3 1333 mhz
Monitor Resolution: 1920x1080
Game Problem: Dying Light
Video Type: MP4 (NVIDIA NVENC)
Hello, i have a youtube channel on which i post "lets plays". Months ago i used mirillis all the time, but i stopped using it because if for some reason the game or mirillis crashed, the video file would be corrupted and unable to even open it, which led to HOURS of footage lost and hours wasted.
Every now and then i hop back to mirillis to check on its progress and see if its worth it. I recently started using it again specially because of the new codec (nvenc). So i started recording my lets play and i spent 60min playing dying light, when i was ready for a break i tried to stop the recording by pressing F9. It didn't work, it wouldn't stop recording, i tried to alt tab and switch to mirillis to see whats going on... Turns out it was crashed, and it was probably crashed since long ago, despite the fact that the icon was saying that the recording was still on. Bottom line, i have 60 mins of recorded gameplay to a 7.5GB video file that is corrupted and i can't do anything with it.
Its really frustrating to have this happening ONLY with mirillis, all other softwares that i'v been using recover the video file after a crash and i can still use the footage.
Just wanted to leave this here, its been happening way t much and i'v wasted too much time. I guess i should have stayed with the other softwares.
Thank you for your time.
Dobs
Re: Mirillis Crashed = video file corrupted
Sun Feb 01, 2015 5:58 am
You are not alone....crashes and lock ups more frequently the last two updates. Like I dumbass I upgraded my version vs keeping the old.
Lost 2 vital engagements to that crash.....
Lost about 5 tonight.
Its getting to the point where I wonder if I shouldn't change software.
No help btw....posted this earlier and with 1200+ vids on youtube, they just wanted to say it was something on my end.
So I'd say move on my friend and find something which may not be as flashy, but no shit works.
Users browsing this forum: No registered users and 68 guests
