SyerNide
PC Specification: Windows 7
Cannot login
Wed Feb 04, 2015 10:29 pm
Hi there
I purchased Action via steam and I am having trouble with the software.
When I want to use Remote Aciton and login via the control panel, it doesnt even want to login. It is just grayed out the whole time.
I have registered an account with this action and the forum but still no connection is being made.
Can you assist me in this matter to sync up my galaxy tab 10 to my computer.
Running : Windows 7
Best regards
Syernide
Re: Cannot login
Tue Feb 10, 2015 6:17 pm
dialt1
Re: Cannot login
Sun Apr 12, 2015 12:28 pm
i can't log in too :(
Markie0425
PC Specification: i7 4770k - GTX 780ti - Windows 7 64bit
Re: Cannot login
Sat May 16, 2015 4:50 am
I was gonna to make another post similar to this issue but I rather not spam.
We can't seem to login with our accounts from Remote Action PC, the setting "Enable Remote Action!" is marked with the Remaining subscription time displaying the correct amount of days. However, when we try to enter the mail and password we used to sign up in the website, we get a "Connection failed!" result.
I already addressed this issue to the customer support email but if anyone has a solution, please let us know, thank you.
Markie0425
Re: Cannot login
Sun May 17, 2015 7:09 pm
No luck, i've tried to reinstall the software and no luck
Re: Cannot login
Tue May 19, 2015 2:09 pm
Return to “Monflo - Remote PC Access and Gaming”
