kcoops78
PC Specification: 8.1, i7-4700HQ, Nvidia GTX 870M
Skipping frames!
Fri Feb 06, 2015 2:09 pm
Action Recorder is missing/skipping frames. I started to notice in post editing when my (externally recorded) audio was out of sync consistently throughout the video (even after re-synching at several points)
I just did a 21 minute screen test recording and by the end the audio and video are 3.07 seconds out of sync. The footage is ahead of the audio which means Action Recorder skipped 3.07 seconds of video intermittently throughout the recording.
My current laptop spec:
Windows 8.1 64bit
Intel Core i7-4700HQ @ 2.4GHz
NVIDIA GeForce GTX 870M
16GB RAM
Is this a software issue or is my laptop performance at fault?
Thank you.
kcoops78
Re: Skipping frames!
Fri Feb 06, 2015 2:13 pm
Sometimes it records just fine, btw.
hej
Sun Feb 08, 2015 8:38 pm
Wow happening on Nvidia as well. I've had this problem for the half year or more. Ended up buying Bandicam since Mirillis seems incapable of fixing the software issue. Don't expect a timely fix, this is a known issue that's quite old.
rugalck
PC Specification: Windows 7, AMD FX-8350, Nvidia GTX690
Mon Feb 09, 2015 9:58 am
Tue Feb 10, 2015 6:03 pm
Sync issues were fixed in 1.22.0.
