cdman2015
PC Specification: i5-2500k, 7970 ghz edition windows 8.1
Action 1.22, no audio on desktop/gaming recording
Mon Feb 09, 2015 2:11 pm
hello, today I am having a problem with action I'm using the latest version of the 1:22, in practice the error is as follows:
when I go to record a video (be it a game session or maybe a tutorial that I am creating the Windows desktop, not recorded the microphone, and only that, because the sound of the game is recorded regularly.
other strange thing is that if I try to record only the sound (so I press F10 instead of the usual F9) the microphone is perfectly recorded.
I also tried to use the built-in microphone in the webcam but also from them when I press F9 to start recording the audio from the microphone is not recorded.
can you tell me how to fix it all ?.
OS: Windows 8.1 x64
Video Card: AMD 7970
Current Driver version and date: Omega (14.12)
Memory: 16 GB
Monitor Resolution: 1920x1080
Recording mode: Game/Application
Video Type: MP4 AMD APP 60FPS
DIGG
Re: Action 1.22, no audio on desktop/gaming recording
Mon Feb 09, 2015 9:42 pm
Did you make sure the Audio device is the one you want the sound to be recorded from?
cdman2015
Tue Feb 10, 2015 8:00 am
hello, I solved the problem before the reply; in practice, I realized that I had a tick on the "record microphone into separate audio track" probably without realizing I had inadvertently put the check on that voice. thanks anyway for having responded.
