Dahnark
PC Specification: I7 3770k GTX 670 Windows 7 64Bits
NVIDIA NVENC: color rendition
Tue Feb 10, 2015 3:03 pm
Hello there,
Why NVENC has a bad color rendition? for example, the red color take a very different tone... You can check it recording a Windows 8.1 screen, selecting windows screen borders to red in personalize and comparing the tone color in video, with the real tone color.
Any way to solve this?
I have a GTX 670 (Gigabyte).
Thanks for your time.
EDIT: Normal MP4 has the same issue too
DIGG
Re: NVIDIA NVENC: color rendition
Tue Feb 10, 2015 4:08 pm
If you showed us an example it would help. By any chance have you checked this:
It's better to chose the full spectrum, for better rendition. (input range to 0-255 that is)
Dahnark
Tue Feb 10, 2015 4:28 pm
Up = real color, down = Action color.
I tried both input range, same results.
DIGG
Tue Feb 10, 2015 5:04 pm
Could you try uploading a small sample? Upload to http://www.sendspace.com/ (don't need to create an account if you don't want to) or GoogleDrive or anyway you want. I'd like to see that.
Tue Feb 10, 2015 5:56 pm
