VexMex
PC Specification: AMD FX8150,MSI gtx 970 gaming 4g, WIN7
You broke it hard :/
Wed Feb 11, 2015 8:22 pm
ok, new hardware, new errors, bugs etc...
my "new" system
AMD fx8150 @4.5Ghz
MSI geforce 970 gaming 4G
Asrock990fx extreme4
24GB Ram
Windows 7
Capture Mode: All
Monitor Resolution: 1(1920x1080) 2(1360x720)
problem in version 1.21-1.21.2:
Audio crackling and speed up/down issues
now in version 1.22 in all modes and formats:
problem from 1.21.2 is gone ... BUT now if i try to capture in 1080p 60fps my video is jerking (#Google translator xD)
AND my audio is capturing only in the first 2-3 seconds and then nothing
ohh, before i forget it: action is crashing ALOT more often since the patch -----> till here is in synchro issue
EDIT: ok, ive tried to capture anything BUT i cant, action is crashing EVERYTIME not once or twice, everytime when i end the captureing..... this is frustrating, sooo please, give me some support on this problem (720p 30fps)
EDIT2:
mode: MP4
format: 720p 30fps
outcome -> instant crash
mode: MP4(NVIDIA blabla)
format 720p 30fps
outcome -> crash at end of capturing or no audio
mode: AVI
format: 720p 30fps
outcome -> if not longer than 4 minutes (i havent tested more) its ok...
EDIT3:
If i capture with avi, i cant use the file
i cant import it into blender
i cant import it into avidemux
i cant import it in the free mp4 video converter
and finally: if i upload the file, youtube cant handle it...
yep, you broke it hard p.s edits are from the wrong section :)
DIGG
Re: You broke it hard :/
Thu Feb 12, 2015 5:23 pm
Capturing in AVI means it uses Action!'s own codec, which isn't compatible with YouTube, and probably a bunch of other programs. I can tell you it IS compatible with VirtualDub (that I know of). If you want to send to YouTube you need to use the converter/uploader included into Action! itself.
As for your crashing problems, I absolutely got none of those, so I don't know what to tell you about that. :?
