Deadlander
PC Specification: AMD FX-6200,AMD Radeon R7 200,Windows8.1
Action incorrectly updated.
Thu Feb 12, 2015 5:16 am
During the automatic update, I got an "Error Opening file for Writing" error, which listed the default program file path and the file action_x64.dll. Ever since then, the program has not operated correctly, and will not update due to the version number being updated even though the update never took place. I am currently unable to capture videos. The error persists even on a clean install. How can I fix this issue?
Re: Action incorrectly updated.
Thu Feb 12, 2015 2:35 pm
Reboot your PC and apply the update again.
DIGG
Thu Feb 12, 2015 5:29 pm
I got the same problem, reboot or not, clean install or update, when it comes to install the action_*.dll it stops, asking me to retry, ignore or cancel. Retrying never works, ignore "works" as the install continues (but skips updating the file of course). It would seem ANOTHER program is using "action*.dll" in its operations. I suspect it's a conflict with NEXTPVR that I also use, but I'm not sure.
I pretty much never update action*.dll from Action! because of that.
Users browsing this forum: No registered users and 54 guests
