RubenB
PC Specification: A10 6800k, 8GB Ram, HD7870, 750Watt XFX
Export audio only from video.
Thu Feb 12, 2015 8:54 pm
Is it possible to only export the audio from a recorded video.
Bacause now, if i want to export the mic sound only, i need to export it as an video file, because there is no audio option.
Also, the recorder video has slow downs and speed ups, but ONLY if i do not export the video. (and i have to use 1.17.xx)
Some help would be great,
Best Regards,
Ruben
Claunator
Re: Export audio only from video.
Thu Feb 12, 2015 9:22 pm
I don't think u can export audio from a video directly but u can basically re-record it so to speak. If u use AVI type, open the video u want and and press "A" so u only hear ur mic, then record it seperately with the audio recording function. I'm not sure if it works with MP4.
That is, if u have time or patience to "re-record" it.
RubenB
Thu Feb 12, 2015 10:00 pm
Thanks for the tip,
did not think of that :)
Mirillis should think about adding a audio export only.
Thanks.
Claunator
Thu Feb 12, 2015 10:44 pm
NP, glad i could help ;)
Users browsing this forum: No registered users and 55 guests
