stick4000
PC Specification: AMD FX 835 processor, windows 7,
action not recording dayz standalone
Sun Feb 15, 2015 8:51 am
hello guys. a few of my friends and myself have been running action for a while, and are also big dayz players. since dayz updated a week or so ago, action will not record it at all. it records the sound but not the screen, and you don't get the timer in the corner. you just get the action splash screen. we are all having the same issue. is this something that others are having trouble with, and if so, is there any solution forthcoming?.
thanks.
neil.
Sir_Spanky
PC Specification: I7 5820, Win 7, R9 290x, 16 GB DDR4, SSD
Re: action not recording dayz standalone
Sun Feb 15, 2015 7:22 pm
stick4000
Tue Feb 17, 2015 11:29 am
thanks spanky. we figured it was a battleye issue, but weren't sure if action was working around it.
Mon Feb 23, 2015 5:24 pm
Currently the only workaround method is to run your game in Windowed mode and capture it with Screen Mode.
Sir_Spanky
Tue Mar 03, 2015 4:44 am
Latest .54 update still not working..
