Rawr
PC Specification: Win7 pro 64-bit, Intel core i5 @ 2.6GHz
Recording gameplay in fullscreen
Wed Feb 25, 2015 4:53 pm
I want to record my gameplay in fullscreen mode in uberstrike.com
It works perfectly with bandicam but when I try to record fullscreen with Mirilis, it looks like this
As you can see the record button is grayed out and I am unable to click it.
On the other hand, desktop mode is working perfectly.
What is the cause of this problem?
Jedimastermace
PC Specification: i5 2500k CPU, NVidia GTX970, Windows 7
Re: Recording gameplay in fullscreen
Sat Feb 28, 2015 3:48 pm
To record in Game mode you have to start the game and then press F9; depending on where the overlay is you should see the Action overlay displaying your FPS and a blue circle (indicating not recording). Press F9 and the circle turns red.
I hope this helps?
Jedi
