Kilda
PC Specification: Win7, i5-3570@3.4GHz, AMD 7800 series
Setting Not Saved, Have to Set Up Every Time
Thu Feb 26, 2015 11:30 am
Dear Developers,
Every time I load up Action!, I need to set the followings:
- Key mapping
- Webcam position
- Volume mix between system and mic
May I know if there is a way to save my preference / setting so that I don't need to set the app up all the time?
PS. After recent patch, Action! tends to crash when I start in-game recording.
Cheers.
Claunator
Re: Setting Not Saved, Have to Set Up Every Time
Fri Feb 27, 2015 8:44 pm
U can get around ur problem pretty easily, do it like this:
Open Action, set it up to ur preferance, then close it. When u re-open Action, the changes u made should be there.
This is a common problem for Action, mine crashes pretty often when i play with my webcam settings. Every change i made before it resets.
