Lol...Buffometer wrote:Editing in MagicYUV or Ut Video codec - better than editing through MakeAVIS (avisynth or ffdshow), these codecs ultra much faster, they are specifically designed for non linear editing software.
I have 9tb for this, and so my videos like "Cinematic Fights", visually the best quality on YouTube. This is for example, for what purpose these codecs.30Gb FICV AVI after reencode using MagicYUV is 800GB size. No way
Buffometer wrote:It decodes to RGB to most NLE and programs, this codec is mathematically lossless, .ficv with higher compression ration - no, MagicYUV and UT Video for high perfomance temporary lossless non linear editing.
For example, If you record a video of the game through magicyuv, the quality will be better (gradients will be much smoother) than in .ficv, but bigger filesize.
Users involved in video editing (with temp results), in most cases using these codecs - because they are ultra high perfomance.
.ficv even visually not lossless, it slightly softens the details and in some places merge colors to reduce the video file size, it almost lossless and quite fast compared to analogs - fraps and e.t.c, but quality very very good.
.ficv better for a one-time recording(small size) with further coding(with editing without temporary results) in the final result, but if you plan to temporary results, then it requires these codecs, .ficv not suitable for this, if you want to keep that quality which was originally recorded in the game (with .ficv).
For YouTube, i did a lot of reencoding and do not complain, because it was necessary for my projects, and because it is non-linear video editing.No need reencode for youtube, its will reencode one more time. 3 reencodes??
I have been looking into Motion-JPEG and would like to know if you had any opinions on the best codec maker for that. I tried picvideo but it crashes Premiere randomly.Buffometer wrote: With MagicYV and Ut Video, it will be native and fast as possible, but with bigger filesize.
