Igorst
PC Specification: 3770k 280x cf
Cities:Skylines - recorded only cursor
Tue Mar 10, 2015 10:57 pm
Dont know whats wrong, but when i record gameplay of cities skylines only cursor is recorded. Any advise?
weskerz
PC Specification: i7 930, GTX 670, Windows 7, 16gb DDR
Re: Cities:Skylines - recorded only cursor
Wed Mar 11, 2015 11:30 pm
I use "Screen recording" instead. It's the second recording option.
Hope it helps. :D
Thu Mar 12, 2015 12:28 pm
Are you recording your video into AVI or MP4 format?
weskerz
Thu Mar 12, 2015 12:46 pm
radi wrote:Are you recording your video into AVI or MP4 format?
On my end, I use MP4. I had the same problem until I used Screen Recording.
JChamberlin
PC Specification: Windoes 7 64-bit
Sat Mar 14, 2015 12:17 pm
I've experienced the same thing.
Using the "Active Screen" recording option appears to work but I don't get the Action HUD in the upper-right corner like I do when I use the "Games and Applications" option. So this isn't ideal.
VexMex
PC Specification: AMD FX8150,MSI gtx 970 gaming 4g, WIN7
Sun Mar 15, 2015 10:29 am
Happens on both, AVI and MP4
Only cursor visible
Modes tried: All
can only capture if Skylines is in windowed mode and then in screen capture
MidnightSnack
PC Specification: Win 8.1 Pro, i7 4770k, GTX 770, 16GB RAM
Mon Mar 16, 2015 12:10 am
I believe the problem is that when the game is set to Fullscreen, it's actually Borderless Window. The black screen happens when broadcasting through Steam's service as well, so it's not just Action! that's having problems.
Mon Mar 16, 2015 11:35 am
Please report your issue to our support team via support@mirillis.com. With provided details they will try to reproduce your issue.
Edit:
It seems that there is an issue with 1920x1080 resolution recording. Can someone of you check if the same issu occurs with 1280x720?
VexMex
Tue Mar 17, 2015 12:40 pm
ok, tried the following:
Skylines @ 1080p and recording with 720p - only cursor
Skylines @ 720p and recording with 720p - works
thanks for the solution ! :)
JChamberlin
Tue Mar 17, 2015 1:18 pm
That really isn't a solution. We should be able to record in 1080p.
