shadowhunter
PC Specification: i5-3670, Gigabyte R9 290X, Windows 8.1
Action trying to record Battlefield 4
Fri Mar 13, 2015 9:32 pm
I have no success when I try to record my Battlefield 4 gameplay, I also think Action is not compatible with the Mantle API (just my guess) can some please help me out?
Best Regards,
Lloyd
Re: Action trying to record Battlefield 4
Mon Mar 16, 2015 11:41 am
Yes, Mantle is not supported. You will not be able to record BF4 with Mantle enabled with Game/Application mode. If you want to capture BF with Mantle enabled you will have to run it in Windowed mode borderless and capture it with Screen Mode.
shadowhunter
Mon Mar 16, 2015 11:55 am
Hi Radi,
Thank you for the reply and a solution, I just wonder will Mantle be supported in the future versions of Action?
Best Regards,
Lloyd
Mon Mar 16, 2015 2:23 pm
shadowhunter wrote:Hi Radi,
Best Regards,
Lloyd
I don't know to be honest. Mantle is not really a standard and probably DirectX12 will kill it.
