Zerreth
PC Specification: Intel i5-4670K, AMD R9 290, Windows 8.1
Recordings stuck @ 856x480 mp4
Fri Mar 13, 2015 10:46 pm
Ever since last update I cannot record anything other than mp4 @ 856x480. No matter what my settings are.
Changing output to AVI, changing framerate, resolution, enabling Hardware Acceleration... They all don't have any effect.
Reinstalling didn't fix it. Are there any preference files that I can delete to resolve this ?
Windows 8.1
AMD R9 290 ( Catalyst 14.12 )
Monitor Resolution: 3840x2160 60Hz
Re: Recordings stuck @ 856x480 mp4
Mon Mar 16, 2015 11:40 am
Please go to your LIVE tab and disable Action! LIVE streaming.
Zerreth
Mon Mar 16, 2015 4:46 pm
I found the solution: force 30bit/pixel was on under general settings. Turning it off fixed everything.
