Hioctane321
PC Specification: AMD FX(tm)-6100, R9 270x 2GB, 8GB Ram
Live Stream Issues
Wed Mar 18, 2015 1:47 am
First off I want to say that I love the performance of Action! I don't think I've ever had a more stable and consistent video capture at 1080p. Great product.
I am having issues streaming to Twitch though. I have to start my stream about 6 or 7 times before it actually connects. It says it's connected, but it never appears on my test machine. The times that it does connect the stream will last about 20 minutes and then it cuts out.
Now I've compared this to OBS and I never had issues with OBS. Is there anyway I can provide you with a log of my stream attempts so that you can analyse the problem? I would prefer to use Action! for streaming because the quality is amazing.
Thanks.
Kam77Kam
PC Specification: I5-4670k, GTX 760, DDR3 8gb, Windows 8.1
Re: Live Stream Issues
Mon Mar 23, 2015 3:45 pm
Same problem please help.
Mon Mar 23, 2015 3:57 pm
Does this issue occurs only with Twitch.tv or also with other streaming services? Hitbox for example.
Hioctane321
Mon Mar 23, 2015 10:26 pm
radi wrote:Does this issue occurs only with Twitch.tv or also with other streaming services? Hitbox for example.
Hitbox has no issues, The stream to it is fantastic.
Tue Mar 24, 2015 8:52 am
Thank you for your feedback. Our developers are currently investigating this issue.
