Steelebourne
PC Specification: i7-4770k CPU, AMD HD 7950, Windows 7
Can't access mirillis.com - get updates?
Thu Mar 26, 2015 2:04 am
I haven't been able to access mirillis.com for a few months from my PC without using a web proxy. It's not being blocked by any security settings or programs, and I hadn't installed anything new or changed any settings before this began. However, I CAN still access it from my laptop with no trouble (but I wouldn't be installing it on that). I use Firefox on both my PC and laptop. I've tried accessing this site using IE & Chrome, but they also say they can't connect.
I loved the trial, and I was all set to buy the full version. I imagine I can do that while using the proxy (I haven't used proxies before now, so I'm not sure), but I don't know if I need to do an online activation to use Action. The really big problem would be updates - assuming that the program updates itself, would I even be able to receive them if I can't access the site normally?
Re: Can't access mirillis.com - get updates?
Thu Mar 26, 2015 3:21 pm
I have sent you a personal message.
