Tschainaik
PC Specification: Windows 8.1, Geforce GTX 560 TI
Multitrack recording
Sun Mar 29, 2015 3:17 pm
Hey there,
I bought a new soundcard just a few days ago, so that I can split every sound track when I am recording. When I record, I need three audio tracks - one for the gamesound, one for skype / TS and one for my own microphone. Is this even possible with Action! ? If yes - how do I have to adjust the program?
Best regards,
Tschainaik
kevintautiva
PC Specification: windows 7 amd radeon 7570
Re: Multitrack recording
Wed Apr 01, 2015 10:27 pm
Hi action allows to record 2 tracks, one for your voice and other for system sounds, so it just records 2 sound tracks you can try adjusting the game sound and the skype sound to have the balance that you want
AnubisAkaLee
PC Specification: Intel i7 4770k, nVidia 770, Windows 8x64
Sat Apr 04, 2015 6:55 pm
As Kevin said, Action! cannot record more than 2 audio tracks. If you want to record 3 audio tracks while using Action! you will need to manually record one of your extra sources using something like Audacity. The lack of audio channels is one of 2 major reasons I don't use Action! as my primary screen capture software :roll:
I totally understand what you are doing. I split my audio into a number of channels so I can adjust them independently as much as I like without effecting the other audio sources. I personally use USB surround sound headphones which work as both a digital audio device, which I set to stereo and play voice chat through, and an analog audio device, which I set to 5.1 surround and record game audio through as a separate track. I then have my USB mic recording to yet another channel. This should be pretty simple for the Mirillis folks to do, but they have no yet added this. Action! has it's place in my work flow if I am capturing from the desktop or windowed applications I find it tends to capture the mouse more reliably than my main screen cap program.
