Frauzi
PC Specification: Windows 8
Action Audio Export Issue
Mon Mar 30, 2015 2:50 am
I have been having a problem recently with Action, When I play the video in Action (open it in the program) its fine, when I export it then play it in Windows Media Player, theres no audio, when i play other videos from the past, there is audio, PLZ HELP :cry:
AnubisAkaLee
PC Specification: Intel i7 4770k, nVidia 770, Windows 8x64
Re: Action Audio Export Issue
Sat Apr 04, 2015 7:39 pm
If you are recording your video with multiple audio tracks (like record mic into it's own channel) you will not hear both audio tracks in media player. Media player handles separate audio channels in the classic way they are generally intended with movies, that they are separate language audio for the same movie source. You would need to mix the audio tracks into single track to hear them in media player. If you did not record your audio into separate tracks did you make sure your media player volume slider is turned up and not muted?
