Deadhand
PC Specification: Windows 7 x 64, i5, GTX 960
Action stops recording on load screens.
Sun Apr 05, 2015 10:01 pm
Today I had an issue with Action only recording up until a load screen. Once the loading screen hits, the recording stops but there is no indication until I alt-tab out of my game to check. I was playing Rage. I had recorded Rage 6 times before with no issue and no other game has caused this so far. I'm using Windows 7 x64, i5, and a gtx 960. I have been using Action for almost a year and this is the first time this has happened.
The only difference is that there was an update to Action, and I added a second monitor. I don't know what else would cause the issue at this point.
Deadhand
Re: Action stops recording on load screens.
Tue Apr 07, 2015 10:36 pm
I found out if I deactivate my second monitor the game records just fine. It's annoying, but it will do.
too-cool
PC Specification: I7, 560TI, win7pro
Wed Apr 08, 2015 10:57 pm
Playing IL-2 1946 on a multiplayer game server and when every I try to start Action the game crashes to the desktop. If I try to record in single player everything is OK, whats funny is that if I start action then load the multiplayer game action will record including the game loading(can be up to 2 minutes of waste) but if I pause the game or alt-tab the game crashes to the desktop. Recording is perfect when recording single player, is there something or some setting I needed to change? Thanks
My Specs
Windows 7pro 64bit
I7 2600K
16gb ram
2gb 560Ti vid (1920x1080 or 1280x720)
23in monitor
240gb ssd (operating system install)
2x 1TB WD HDD (d & e) recording save on d
Sound Blaster
Track IR5
Saitek X55 controller
