Honkiman
PC Specification: Lenovo Y50-70 running Win8.1
Action not starting up
Mon Apr 06, 2015 8:35 am
Hi there,
I'm currently experiencing the problem, that action won't start properly. I'm getting the start overlay on my desktop, but nothing else. It is getting stuck there over and over again. I'm using the latest version of Action (1.24.3) on Windows 8.1. I also attached the windows event viewer entrees regarding this problem. I'd also like to add that I already remove Action from my computer, cleaned the registry and re-installed it without success.
Does anyone have a solution about this?
Thanks in advance,
Honkiman
Action Crash.zip
(6.82 KiB) Downloaded 432 times
Honkiman
Re: Action not starting up
Thu Apr 23, 2015 6:14 pm
bump
Fri Apr 24, 2015 11:51 am
Check if your screen refresh rate is not set to 30Hz instead of 60Hz.
Honkiman
Sat Apr 25, 2015 9:48 pm
Monitor is set to 60Hz. The build in laptop monitor is set to 48Hz though.
Tue Apr 28, 2015 9:51 am
Honkiman wrote:Monitor is set to 60Hz. The build in laptop monitor is set to 48Hz though.
Hmm.. could you post your dxdiag?
Asa
PC Specification: i7-3820, AMD R9-290 + R9-295X, Windows10
Thu Apr 30, 2015 11:13 am
radi wrote:Check if your screen refresh rate is not set to 30Hz instead of 60Hz.
Sorry to hijack the thread, but does Action fail at 30Hz? Perhaps open for a second or two and then crash? :?
Honkiman
Wed May 06, 2015 12:11 pm
Hey radi,
I attached the dxdiag.txt in a zip file.
DxDiag.zip
(16.58 KiB) Downloaded 439 times
alexneal2003
PC Specification: 8.1
Sun May 10, 2015 6:59 am
I followed what you said but action just freexes for unlimited time on the mini startup gui
Please reply as i bought it yesterday it worked then but now no
alexneal2003
Sun May 10, 2015 7:03 am
It dosnt work for me to and it just freezes on startup untill force stop
i bought it yesterday and this is getting annoying as i was playing record
i followed how you hellped that other guy
please reply
Honkiman
Tue May 19, 2015 11:52 am
bump
