DevGamerrr
PC Specification: Windows 8.1
Problems with Microphone
Fri Apr 10, 2015 9:17 am
To record my microphone i have to tick Listen to this device in the sound control panel. But then my mic echoes when i preview it.
Windows 8.1
AMD A4-5000 APU with Radeon HD Graphics 1.50 GHz
4 GB of Ram
Blue Snowball Microphone
Someone please help this is very frustrating :evil: :evil: :evil:
Re: Problems with Microphone
Fri Apr 10, 2015 3:11 pm
Could you post a screenshot of your Action! audio settings?
DevGamerrr
Sat Apr 11, 2015 7:51 am
radi wrote:Could you post a screenshot of your Action! audio settings?
image- http://imgur.com/VYxAHkU
Thu Apr 16, 2015 1:26 pm
It seems that you are using "Record microphone into separate audio track" feature. What you should know about "Record microphone into separated audio track" feature is that it creates an additional audio track in your video file. It dśs not create any additional file. While you are playing back your video file you will hear only one audio path at time. To switch between active audio track please press "A".
