Frozennnn
PC Specification: Quad core amd phenom 3.6 ati hd 5670 XP
I need Solution for this
Thu Dec 08, 2011 11:17 pm
Hi hours ago i buy the pro version of the player because is the best player in the world but all thing have a defect u.u mi problem is the next
Audio #1
Format : TrueHD
Codec ID : A_TRUEHD
Duration : 1h 7mn
Bit rate mode : Variable
Maximum bit rate : 2 604 Kbps
Channel(s) : 6 channels
Sampling rate : 48.0 KHz
Bit depth : 24 bits
Compression mode : Lossless
Title : 5.1
Language : English
Audio #3
Format : AC-3
Format/Info : Audio Coding 3
Mode extension : CM (complete main)
Codec ID : A_AC3
Duration : 1h 7mn
Bit rate mode : Constant
Bit rate : 448 Kbps
Bit depth : 16 bits
Compression mode : Lossy
Stream size : 215 MiB (2%)
Title : 3/2+1
Language : Spanish
the file have this 2 audios english and spanish
The spanish runs well but the english no sound so i need help for this because the spanish sound is s*** im from argentina but i want the english sound because is the real sound plz help me
PD: The player, motion , and video runs perfect.
P.J
Re: I need Solution for this
Fri Dec 09, 2011 11:17 pm
Splash doesn't still support Dolby TrueHD :(
Styvesant
PC Specification: 3570K, 680, 8gb RAM, Windows 7 (x64)
Mon Jan 02, 2012 10:25 am
I love when people claim that they bought the software, it sure is funny.
Splash PRO
Thu Mar 22, 2012 12:26 am
Like P.J wrote, Splash does not decode TrueHD audio.
It can be only bitstreamed.
If audio includes core AC3 sound Splash will decode it.
In this case audio track probably does not include core AC3.
P.J
Tue Mar 27, 2012 7:19 pm
Ghost wrote:Like P.J wrote, Splash does not decode TrueHD audio.
But VLC can play even without core :cry:
