Cookie
PC Specification: Intel Xeon E3 1245v3, AMD Radeon HD 7970
Bad Video Performance
Thu Apr 16, 2015 12:12 am
Hey Community,
I have a big Problem. I have a very bad Video Quality while recording. I record Arma 3 and have many pixels in my record. Here a harmless show of it. http://youtu.be/GKibFSgeu60
If i have action ingame like running, fire with enemys or something else its harder. Here my settings:
If I record with AVI I dont got this problem but I get a file size with 1GB per minute.
Can you help me? Why is the quality so bad?
I am sorry for my bad englisch. If you dont understand something ask me.
Greetz Cookie
Re: Bad Video Performance
Thu Apr 16, 2015 1:21 pm
AVI is almost lossless compression which produce higher quality files but the con is larger files. MP4 files use h264 compression which is a loss compression and the video quality will be always worse than AVI.
Cookie
Thu Apr 16, 2015 5:49 pm
I know this but, how can nvidia shadowplay with smaller files get a much better qualitiy then amd app in bigger files? And why is this quality so bad? Cause of bitrate?
Fri Apr 17, 2015 12:47 pm
Cookie wrote:I know this but, how can nvidia shadowplay with smaller files get a much better qualitiy then amd app in bigger files? And why is this quality so bad? Cause of bitrate?
Nvidia API offers a bit better image quality. You would get almost the same results as Shadowplay using MP4 NVENC in Action.
Users browsing this forum: No registered users and 44 guests
