Paveloony
PC Specification: CPU:I7 4770k;GPU:NVidiaGTX780oc;Win7 64b
System sound conflict
Fri Apr 17, 2015 12:16 pm
Hey
When i start the recording (desktop mode) everything is ok,but when i'm entering any folder
electro noise appears in the background.
The noise is not recorded,however,its very annoying.
When i'm unchecking "Record system sound" in the application it's gone.
Also,when the "Record system sound" is checked but the Windows mixer System sound is muted there is no noise.
Of course i do want to record the system sound so that's not a solution.
I'm only using my headphones connected to the front input jack.
There is no other speakers connected to the computer.
It sounds like some applications sound conflict, but i just can't find what it is....
Thank you
Paveloony
Re: System sound conflict
Fri Apr 17, 2015 12:49 pm
Could you post a video sample where your issue occurs?
Paveloony
Fri Apr 17, 2015 1:49 pm
radi wrote:Could you post a video sample where your issue occurs?
One other strange thing,when windows media player is open the background noise is gone
How do you want me to post a video sample?
Fri Apr 17, 2015 1:54 pm
You can upload it to YouTube or send the raw file to Google Drive or Dropbox.
Paveloony
Fri Apr 17, 2015 2:16 pm
Ok
I'm uploading the raw file to my second YT channel
It will take a few moments
Also my English is not perfect,it's a little bit hard for me because i'm from Israel
So please don't judge me by that ;)
Paveloony
Fri Apr 17, 2015 3:22 pm
This is a link to the video http://youtu.be/gJ2EmLqNx6c
Grzyby15
PC Specification: AMD Athlon X64, Geforce, Windows 7
Thu May 07, 2015 8:01 am
Check all the cables and connections. Used to have problems with sound, replaced all cables for more expensive copper ones.
Return to “Monflo - Remote PC Access and Gaming”
