YonaPN
PC Specification: I7 3,40ghz, GT555m, Windows 10 Pro X64
Is possible resize webcam resolution?
Sat Apr 18, 2015 10:45 am
Hello, I'm testing Mirillis, and it seems incredible so far (very good quality and 0 lag) before using OBS and sufficient cause lag.
But I have seen that the resolution used for the webcam is quite low.
I would change the resolution of the webcam.
My webcam is Logitech G920, Support 1920x1080 but I want the record webcam With resolution of 864x480.
Is this possible?
I look forward to hearing a yes to buy this program and start enjoying him.
Regards.
Re: Is possible resize webcam resolution?
Sun Apr 19, 2015 6:10 pm
Unfortunately no. Action! will capture original webcam video stream.
