Zargonan
PC Specification: Win7x64 4790k@4.4Ghz Gtx980SC 16GB
Audio Questions
Wed Apr 22, 2015 7:10 am
Using Action! 1.24.3.0
Is there any way to record multiple audio sources which in my case would be TeamSpeak 3 and a game since with my Turtle Beach z60 headphones there are differently adjustable outputs for sound and communications?
Also, is there a way to record surround sound or record in stereo while playing the game with surround sound(also using the z60)?
If there is no way to do it using only action then multiple programs would work as well.
Re: Audio Questions
Wed Apr 22, 2015 3:17 pm
There is no possibility to record another application sound into separate audio track.
Kam77Kam
PC Specification: I5-4670k, GTX 760, DDR3 8gb, Windows 8.1
Re: Audio Questions
Wed Apr 22, 2015 7:29 pm
radi wrote:There is no possibility to record another application sound into separate audio track.
I was wondering about that. I've imported my recorded video into Sony Vegas then realized that there is only one audio track, do you think it would be possible to be able to separate them Into their own program. That may have sounded a little confusing so let me give you an example.
Example: Say you are talking someone on teamspeak and you are playing a game. (With me so far?)
When you made the video and you import it to Sony or premiere or what ever, you realized that your buddy from teamspeak is screaming in the mic in the video, think it would be possible to separate the tracks so you can turn down your friend?
Maybe if you wanna check out my other request that would help "Action" click on this other topic: http://forum.mirillis.com/viewtopic.php?f=36&t=36401
Zargonan
Re: Audio Questions
Thu Apr 23, 2015 10:30 am
Well then could I possibly request it to be a feature at some point?
