Frozennnn
PC Specification: Quad core amd phenom 3.6 ati hd 5670 XP
I need Solution for this
Fri Dec 09, 2011 3:07 am
hi this is the best player in the world but i have a problem with the sound of mkv check this
Audio #1
Format : TrueHD
Codec ID : A_TRUEHD
Duration : 1h 7mn
Bit rate mode : Variable
Maximum bit rate : 2 604 Kbps
Channel(s) : 6 channels
Sampling rate : 48.0 KHz
Bit depth : 24 bits
Compression mode : Lossless
Title : 5.1
Language : English
This is the sound of mkv i dont now why the media player clasic dinosaur times edition plays this file well and this player 2 weaks update ago dont i buy the splash pro because is a best player and the fps are fantastic so plz i need a solution
P.J
Re: I need Solution for this
Fri Dec 09, 2011 11:22 pm
Already answered in your previous topic.
Thu Mar 22, 2012 12:23 am
Like P.J wrote in other topic, Splash does not decode TrueHD audio.
It can be only bitstreamed.
If audio includes core AC3 sound Splash will decode it.
In this case audio track probably does not include core AC3.
