mirillispleasehelp
PC Specification: Windows 8.1
Exporting problem
Fri Apr 24, 2015 10:42 pm
I'm having a problem when exporting.
When I try to export it gets to 30% max and then doesn't progress further while eta rises.
If i then stop and export it again, it will be stuck on 0%.
If I close Action! and try again it will pass zero but will still get stuck at a random point, different every time.
I've tried disabling hardware acceleration but it's still the same.
Please help,
Thank you. :)
Re: Exporting problem
Mon Apr 27, 2015 5:55 pm
Do you use hardware acceleration for video exporting?
