kolo2300
PC Specification: AMD Athlon II X2 250 3GHz, Gt 430, win7
Mirillis Action and VisualBoyAdvance
Sun May 03, 2015 12:06 am
Hi, i'm new and i need help. When i recording any vba game it's ok no lags everyting ok, run smoothly. When i stop recording and previev my video it's lagging as hell. Here is my test movie made with action : https://www.youtube.com/watch?v=6i0yKsscZZk
My PC specification:
GPU: GeForce GT 430
Processor: AMD Athlon II X2 250 3GHz
Ram: GoodRam 4Gb
kolo2300
Re: Mirillis Action and VisualBoyAdvance
Sun May 10, 2015 4:13 am
Thanks man, AVI works perfectly but is there any way to "fix" mp4 recording? Or is there any converther working with FICV? I know Mirillis have own converter witch is great but i used to convert many movies at the same time- one after one in line and Splash Pro Ex supports only one movie per Export. I have to weak pc for mp4? But anyway I'm in your debt cederick. When i record to mp4 60 fps 480p 1:00 record is 13-30 mb, Avi 60 fps 480p 1:00 record is 250mb O.O.
It's werid for normal games and emulators works smoothly but VisualBoyAdvance is still little lagging not as much as before but it's not perfect and file size is horrible big. Soon i'll upload my avi record.
kolo2300
Sun May 10, 2015 1:44 pm
Ok thanks.In older versions of Action! it have Cuda support can i enable it it present version?
Tue May 12, 2015 3:54 pm
kolo2300 wrote:Ok thanks.In older versions of Action! it have Cuda support can i enable it it present version?
CUDA support has been removed by NVIDIA with one of the recent driver versions.
