Weegie
PC Specification: i7-3820,GEForce GTX 780,Win 7 (64)
Action Crashing Battle of Stalingrad
Mon May 04, 2015 6:29 pm
Same symptoms as the Minecraft thread
Apologies for first post being a cry for help, just never had issues before. Its been a while since I used it and it performed an upgrade, prior to this Action has always been fine with no problems
Weegie
Re: Action Crashing Battle of Stalingrad
Tue May 05, 2015 4:42 pm
Never mind solved it
I read that Action can have issues with Sweet FX, I guess this is still the case.
I was running Sweet FX, so I disabled it and Action runs fine.
If using Sweet FX I recommend the Sweet FX configurator tool or JSGME as that way they can be easily enabled or disabled as required
