Alvagore
PC Specification: AMD FX 8350 x8 4,0 ghz, Geforce gtx 470
Where do i install Action?
Sat May 09, 2015 8:36 pm
This might sound like a dumb question, but i need an answer, i have 2 hard drives, the first one has installed the OS, Programs, and all that stuff, and the second hard drive is destinated just for videos recorded with Action, i need to know where should i install Action, in the first hard drive which it has Os and Softwares or in the second one?
Alvagore
Re: Where do i install Action?
Sun May 10, 2015 8:59 pm
Thanks for the reply but i really would like an answer from a developer since there is no one that knows better their software than them.
Tue May 12, 2015 3:53 pm
There is no required destination to install Action. It's recommended to use default format but you can install it on your second hard drive.
