ToniRG
PC Specification: I7-3820, GTX 970, Windows 8.1 64 bit
Error Action Nvencoder Nvidia drivers 352.86
Tue May 19, 2015 11:22 am
With the latest Nvidia 352.86 drivers, Action gives error when trying to record to MP4 (NVENC).
With 350.12 this does not happen.
The error is attached to the image.
Error Mirillis.jpg (109.44 KiB) Viewed 26848 times
TommyP
PC Specification: Win 7 x64
Re: Error Action Nvencoder Nvidia drivers 352.86
Tue May 19, 2015 11:46 am
I got the same problem, yesterday i got an update of nvidia and today i wanted to record something with MP(Nvidia Nvenc) and got an error right away on all 3 modes, gameplay, desktop and screen regio.
Tue May 19, 2015 2:03 pm
This issue is related to faulty driver version or installation issue with your recent video driver. Driver re-installation or switching to another format should help.
DKsDEVIL
PC Specification: I5 2500K, Gtx 770, win 7 64 bit,
Tue May 19, 2015 2:16 pm
have the same problem the new driver do somting.
maby mirilla have to contact nvidia to fix this.
TommyP
Tue May 19, 2015 3:59 pm
radi wrote:This issue is related to faulty driver version or installation issue with your recent video driver. Driver re-installation or switching to another format should help.
Already did that still same. But yes other format helps, but still want to use mp4(nvidia nvenc) :3
Tue May 19, 2015 4:08 pm
Currently the only workaround solution to this issue is to install previous driver version, change your MP4 format or Ignore that message so your recording process will be started or stopped properly.
TommyP
Tue May 19, 2015 4:20 pm
radi wrote:Currently the only workaround solution to this issue is to install previous driver version, change your MP4 format or Ignore that message so your recording process will be started or stopped properly.
Maybe the next update will fix it.
Btw with the error, you cant record anymore cause of the error. so either avi or mp4
ToniRG
Tue May 19, 2015 4:22 pm
As a workaround use AVI, but all other programs that use NVENC not fail, as OBS, I hope that the error is repaired in an update.
filipeg165
PC Specification: i7 4770K, GeForce GTX 770, Windows 8.0
Wed May 20, 2015 1:21 am
Got the same error, just updated drivers yesterday for Witcher 3 launch and started getting this error... Regular mp4 works fine but makes me feel its not right...
Wed May 20, 2015 11:04 am
Issue fixed in 1.25.0
DOWNLOAD HERE: http://bit.ly/ActionDownload
