GamerGuy
Won't start after installing 1.25.0 update
Wed May 20, 2015 4:16 pm
When I try to start Action it now pops up and says:
Critical Error 106
Failed to initialize product. Please install Action in program files directory.
Everything was working fine before this. Windows 8.1 Pro.
freeleecher
PC Specification: 2700k 2x290 windows 7
Re: Won't start after installing 1.25.0 update
Wed May 20, 2015 4:18 pm
Same thing here aswell.
action_1_24_3_setup.exe link below
:mrgreen: :oops: :roll: :lol: :ugeek: :idea: :D :shock:
khangnhi
PC Specification: Windows
Wed May 20, 2015 4:28 pm
Going back to 1.24 did not work?
disi
PC Specification: AMD all the way
Wed May 20, 2015 4:55 pm
same here
GamerGuy
Wed May 20, 2015 5:05 pm
Does anyone have a link to the previous version installer? So far support isn't responding.
noahphense
PC Specification: i7, 980m, w8.1 standard
Wed May 20, 2015 5:30 pm
I fixed the issue. So when Mirillis approves this post, they should approve my "fix" post. Which will be a thread in the main Action! area.
Cheers!
disi
Wed May 20, 2015 5:40 pm
GamerGuy wrote:Does anyone have a link to the previous version installer? So far support isn't responding.
I still had the 1.21 version on my drive. There is a download on techspot (google) of a previous version.
GamerGuy
Wed May 20, 2015 5:49 pm
You know I just want to rant a bit while searching for the prior version all I can find are tons of cracked versions on pirate sites. So it is clear this STUPID policy of Mirillis of not allowing their legit customers to have easy access to the previous versions is having zero effect on piracy issues. All it is accomplishing is preventing me this morning from being able to use software I paid for.
Borz
PC Specification: Windows 7
Wed May 20, 2015 5:59 pm
Getting the same issue here. It's disheartening, as I just decided to record something today and will now have to wait.
MeisterMonty
PC Specification: Win 8.1, AMD FX 8350, GTX550ti,8GB RAM
Wed May 20, 2015 6:56 pm
I've found some installers on my disk but I dont know if I'm able to upload one here ... :cry:
