Solution to Critical Error 106
Thu May 21, 2015 2:08 pm
Recently group of our users was affected by Critical Error 106. This issue is related to User Account Control turned off.
To turn UAC on
Open User Account Control Settings by clicking the Start button Picture of the Start button, and then clicking Control Panel. In the search box, type uac, and then click Change User Account Control settings.
To turn on UAC, move the slider to choose when you want to be notified, and then click OK. Administrator permission required If you're prompted for an administrator password or confirmation, type the password or provide confirmation.
Restart PC.
Please notice that this is currently a temporary solution while we are looking for a permanent one.
noahphense
PC Specification: i7, 980m, w8.1 standard
Re: Solution to Critical Error 106
Thu May 21, 2015 2:13 pm
I am not using UAC. I fixed the issue with this method in the link below.
http://forum.mirillis.com/viewtopic.php?f=36&t=36584
- np
disi
PC Specification: AMD all the way
Thu May 21, 2015 2:15 pm
We could also just not update. This is what I am going to do until it is working?
Do you know how long this will be the case?
Will we be notified?
p.s. or more precise, will I never be able to upgrade with uac turned off?
GamerGuy
Thu May 21, 2015 2:16 pm
I had UAC off, tried turning it on, and this did not solve it for me.
Thu May 21, 2015 3:36 pm
GamerGuy wrote:I had UAC off, tried turning it on, and this did not solve it for me.
Have you rebooted your PC?
MeiVincible
Thu May 21, 2015 6:43 pm
After lot of work finding a way install action 1.25.0 in the default directory (because it wasn't with my previous version), I can confirm this does make it to load properly. I may however downgrade anyway, and waiting for a proper solution.
And I suggest people uninstall 1.24.3 or lower, before messing with 1.25.
The steam version doesn't seem to be affected.
Thu May 21, 2015 7:34 pm
Fixed in new release (1.25.1)
Update here: https://mirillis.com/en/downloads/downloads_action.html
