MozartMan
1.25.1 Still Not Working After Fix!
Thu May 21, 2015 8:40 pm
I just installed fixed 1.25.1 version and it still not working. My UAC is off and I am not turning that stupid thing on.
Everything was good till version 1.25. Mirillis team, please fix it.
TirexiHD
PC Specification: i7 5930k, 32GB DDR4, GTX1080, Win 10.
Re: 1.25.1 Still Not Working After Fix!
Thu May 21, 2015 10:27 pm
1.25.1 is working fine for me.
THX Mirillis.
<<<Rampage V Extreme - i7 5930k @ 4.5Ghz - 32GB DDR4 3000Mhz - MSI GTX 1080>>>
MozartMan
Thu May 21, 2015 10:52 pm
TirexiHD wrote:1.25.1 is working fine for me.
THX Mirillis.
Is your UAC on or off?
TommyP
PC Specification: Win 7 x64
Fri May 22, 2015 4:19 am
MozartMan wrote:I just installed fixed 1.25.1 version and it still not working. My UAC is off and I am not turning that stupid thing on.
It's working for me also.
TirexiHD
Fri May 22, 2015 5:29 am
THX Mirillis.
UAC Off.
After Windows install my first step this s.it UAC turning off.
Fri May 22, 2015 11:30 am
Have you tried rebooting your PC?
MozartMan
Fri May 22, 2015 12:41 pm
OK, I fixed my Action! 1.25.1.
Reboot didn't help. The issue was that Action! was set to run as administrator, and when I unchecked it it worked.
But why all these four years since I bought Action! all previous versions worked fine when run as administrators?
What did you guys at Mirillis do to make troubles for many users?
1. You can no longer change installation folder
2. You cannot run 1.25.x as administrator
What was the purpose?
