Paul80
PC Specification: Windows 8.1 64 bits - ASUS N73SM 6gb ram
Problem with LIVE STREAMING YouTube of Action! 1.25.1
Sun May 24, 2015 2:13 pm
I have a problem with the option LIVE STREAMING Action !. I have the 1.25.1 release.
When I want to do a live, YouTube tells me all the time in "Flow State": Bad.
Here is my Speedtest : Image
I put in the 2 sides (Action and YouTube!): 1080p 60fps
In Bitrate I put 12,000 or 9,000 or 7,500, this does not change.
Such 720p 60 fps.
I have put the YouTube profile.
The name of the stream, the primary server is filled ...!
I in fashion Games / Applications or active desktop mode.
I have a laptop (ASUS N73SM with 6 GB of RAM).
Here is the YouTube error message:
Main stream:
Please use a key frame rate less than or equal to 2 seconds. Key frames are not sent frequently, which will cause a buffering. Current key frame rate: 6.0 seconds. GOP sizes can be erroneous if integration errors.
The stream running all the same but with many rampages, it works very badly.
Thank you for your help in advance,
Paul
Re: Problem with LIVE STREAMING YouTube of Action! 1.25.1
Wed May 27, 2015 3:52 pm
