The Renegadist
PC Specification: Intel Core I7, Nvidia Geforce 755m, win7
1.25.1 Action Bug - Records but Corrupts the Video File
Sun May 24, 2015 8:05 pm
After upgrading to the newest version of Action I attempted to record a game at 60fps with the quality at 720p and for the entirety of the recording everything was going just the way it was supposed to. After an hour and a half of recording I said my goodbeyes and ended the recording only to find that the video had somehow glitched. The video file had saved with the proper date and time but the size of the final video was 256kb when an hour and a half usually leads to a ten gig file. The thumbnail of the video file also isn't showing telling me that somehow upon ending the recording it had corrupted. I tried to open the video file and nothing happens. I lost alot of good footage which due to the game I can't go back and re-record what I did. Is there a fix I can do to stop this from happening or is there a fix that is in the works that will fix this problem.
Thanks!
Re: 1.25.1 Action Bug - Records but Corrupts the Video File
Mon May 25, 2015 9:18 am
