Aleandria
PC Specification: windows 7, nvidia cuda
Is there a fix for this?
Fri May 29, 2015 5:55 pm
I just started using the trial version for the action recording software and I'm noticed that every time I've exited the program and then started it again, I have to completely redo the settings. It doesn't save the settings! It's really annoying. I am considering purchasing this as it seems like a good recording software, but not if I have to keep changing the settings every time I use it. Also, for some reason once I minimize the window I can't get it back up again. At all. None of the settings are interfering, I just can't open the window again so I have to close the program and then open it again (which is why I noticed the above issue).
Please let me know if there is a fix for this as I've tried 6 other game recording software and this is the best so far. I'd like to keep it. Thank you!
Intel(R) Core(TM) i7-2630qm cpu @ 2.00ghz
8gb Ram
64-bit Windows 7 OS
NVIDIA Cuda 2gb
Aleandria
Re: Is there a fix for this?
Wed Jun 03, 2015 4:36 pm
Is anyone willing or able to help?
Mon Jun 08, 2015 5:47 pm
Please notice that this is only a community forum. If you did not received any help here I recommend to contact our support team directly via support@mirillis.com.
