mangomel
PC Specification: Intel 6400 2x2.0 Radeon HD3470 Windows 7
How to make Splash much better
Fri Dec 09, 2011 11:21 am
I know that Splash must be easy to use and I agree that. But there's few functions which absolutely, I repeat: absolutely, must be added.
First of all to make video look much better is denoiser / noise filter / noise reduction. Modern studio cameras still have a problem with high noise level in low light. F.e. the movie "Black Swan" (2010) is highly noised and in hd it looks not so good.... Most of HD TVs has such filter. What is more, if we turned noise reduction off in HD TV and we compared it to modern PC monitor, then we would notice that PC screen shows noise more intensively than TV. So this options is highly needed. The amount of filter should be adjustable like other options (light etc.)
Second option is colour correction. A lot of older movies (1995 and older) has not natural colours although they were digitalized and stored in HD. For example most popular films of 70s and 80s has an 'admixture' of red colour. Faces are too red and sky isn't cyan-blue but rather violet(magenta)-blue. However, I also saw some movies which were too yellow-green. Anyway, there should be a single slider which would change overall color tone (Hue) similar like in Photoshop but with more narrow band. I would enjoy it very much.
Last option or rather an improvement is case of subtitles. They should display a proper charset. As soon as I see it can't (actually polish). Also a position of subtitles should be easily adjustable f.e. by dragging up / down by mouse.
P.J
Re: How to make Splash much better
Fri Dec 09, 2011 11:29 pm
For the first and second ideas, you can use the video card options.
Are you sure the movie is from original bluray not x264 ripped? :?
Thu Mar 22, 2012 12:24 am
Hi and thanks for a nice feedback.
About subtitles, it is planned to be possible to move it with mouse in the future versions.
Currently is should siplay polish charc properly, please make sure that you have set a correct encoding in subtitles settings.
Noise (film grain) and denoise are also planned but nto for the nearest future.
We do not plan to add hue but I will add this to our list of suggestions.
Thanks again for the feedback!
