LeKris
PC Specification: Intel Core i7, Windows 10 x64 , 16GB RAM
Compatibility for Windows 10
Tue Jun 02, 2015 6:27 am
I tried to search something similar regarding to this
topic, but I only get a result like "too common words".
My question is really simple:
Will Action! be compatible to Windows 10?
At the moment I am using Windows 8.1.
As far as I know there will be a free upgrade to Windows 10
during the first year after the release (which is suggested on July 29th 2015). So I am going to use
this offer since it is free.
Will Action! also work with this OS?
Do you plan a new release which will be compatible?
Greetings
LeKris
Keep calm and play some games
Re: Compatibility for Windows 10
Tue Jun 02, 2015 9:42 am
Windows 10 is not officially supported yet. However it should be working on current build.
