gordon shumway
PC Specification: Windows 7 Pro 64 Bit. Intel Core i7 3770
Individual Audiotrack (Microphone)
Thu Jun 04, 2015 7:51 pm
Hi to all. Bought the Action Screen Recorder today. My Question is, where can i find the seperate Audiotrack from the Microphone ? When i recording some things on the screen, there is only the the sound from the used soundcard in the video. But the Microphone Audio is not in there. Where can i find the seperate Mic Audio when this Option is enabled ? Another Question is, can i not recording all the things via an external soundcard that use an ASIO Driver ? For example, i wanna record the screen when i doing some things in Cubase and wanna speek some Comments via the Mic Input from this external soundcard. But the Action Screen Recorder doesn't record the Sound that comes from the external Soundcard. Could this a problem caused by the ASIO Driver ?
Hope for some hints where i can find the seperate Mic Audiotrack.
Thx and greetings.
Re: Individual Audiotrack (Microphone)
Mon Jun 08, 2015 8:33 am
"Record microphone into separated audio track" feature creates an additional audio track in your video file. It does not create any additional file. While you are playing back your video file you will hear only one audio path at time. To switch between active audio track please press "A".
gordon shumway
Mon Jun 08, 2015 5:24 pm
Hi, thx for your feedback. Yes, was my fault. Thought Action creates an seperate Audiotrack. But now all is clear. Can you please say, if it's possible that you could give ASIO Support with Action in the Future ? That would be a great feature.
Greets
Mon Jun 08, 2015 5:41 pm
I'd recommend to contact our support team about this question. You can reach them via support@mirillis.com.
