oSleepleZzZ
PC Specification: Intel Core 2 Quad 2,33, win7 64 Enterpri
error after 1.25.3 update
Tue Jun 09, 2015 2:44 pm
everytime i try to start Action i get this error
its the latest version ..
and i cannot choose where to install the programm
Re: error after 1.25.3 update
Wed Jun 10, 2015 8:41 am
Where is your Action! installed?
GerhartRTFO
PC Specification: i7-8700/5820/3770| gtx1070/970/680 win10
Contact: YouTube
Wed Jun 10, 2015 7:43 pm
radi wrote:Where is your Action! installed?
I can probably answer this as I have the same issue. It installs it in Program Files (x86). I've also been in contact with support to let them know of the situation funny thing is I did find a solution until it is fixed.
Copy the folder Mirillis along with the installed Action! from the Program Files (x86) and paste them to the directory Program Files. Now delete the installed version from Program Files (x86), don't uninstall but delete it instead so that all of the entries are left in the registry. You should now be able to run the software.
Support asked me if I was able to record videos after doing this and I replied that I could record with no issues. I haven't heard anything back yet. I'm assuming they will fix the installer/update to reflect this issue but until then this is my work around. oSleepleZzZ I hope this helps you out until then and radi I hope this helps answer your question.
oSleepleZzZ
Thu Jun 11, 2015 5:35 am
on a different HDD
i got 8 HDD's installed and actually the installation folder is
E:\Action!
the thing is i can install all versions till action 1.24.3 without any problems ..
but with 1.25.1 - 1.25.3 i get these errors
and thx for your lil workarround bro
but i downgraded to last "stable" (for me it was 1.24.3) version ..
i can wait for a fix
(hope i dont get something to read like: I need to put UAC on/off or such things . it runs before so it should be run now)
oSleepleZzZ
Wed Jun 17, 2015 5:17 pm
HELLO????
Thu Jun 18, 2015 10:25 am
Please try moving your Mirillis folder from Program Files x86 to Program Files and see if that helps.
naveedkm
PC Specification: Windows 7 SP 1 64-Bit, Intel Core i7
Sun Jun 21, 2015 1:28 pm
oSleepleZzZ wrote:on a different HDD
E:\Action!
But how did you do the downgrade?
